XGIMI projectors harness the power of Android TV to bring cinematic entertainment to your home
Xgimi 2021.035442re
Xgimi 2021.035442re (Image credit: XGIMI)
If you're after an immersive cinematic experience, then XGIMI's range of set-up free projectors can do just that. Powered by Android TV, you don't even need to plug anything in to watch the latest TV shows and movies from the likes of Disney+, HBO Max and Amazon Prime Video. All you need to do is place these projectors where you want, and they'll automatically adjust themselves to offer you the very best possible image quality.
With built-in Chromecasts, you're also able to easily stream media from your Android smartphones and tablets as well. Best of all, for Black Friday these projectors are getting some hefty price cuts as well.
Night
Source: XGIMI (Image credit: Source: XGIMI)
HORIZON Pro
If you're after stunning 4K footage for a truly immersive cinematic experience, then the XGIMI HORIZON Pro will be for you. Packing true 4K technology and offering ultra-bright 2200 ANSI lumen images, movies and TV shows that you stream are going to look amazing. This is thanks to its advanced X-VUE 2.0 image engine with super-smooth motion, plus support for stunning HDR10 content.
With Android TV built-in, you also have instant access to a huge library of apps and games, including popular streaming services like Disney+ and Hulu, and you can stream directly from your Android device as well thanks to its built-in Chromecast.
TV shows and movies won't just look incredible, either, but they will sound amazing as well, thanks to the Horizon Pro's powerful Harman Kardon speakers which offer DTS-HD, DTS Studio Sound, Dolby Audio compatibility, offering room-filling audio.
During Black Friday, the HORIZON Pro will have a 12% price cut, between November 26 - November 30, cutting the price to $1,499. Plus, the 1080p model will have 15% off, cutting the price to $934, the lowest of the year.
Bed
Elfin
Enjoy crystal-clear 1080p movies and TV shows on a huge 150-inch screen with the Elfin projector, which offers incredibly high 800 ANSI lumen brightness, making it one of the brightest LED projectors of its size, which enables to you use it both day and night, with Harman Kardon speakers offer incredibly rich and detailed DTS and Dolby audio.
It also comes with the power of Android TV 10.0, allowing you to access over 5,000 apps from the Google Play Store, including streaming services such as Hulu, HBO Max and more.
Screen Adaption
Not only does this projector look - and sound - fantastic, it's also incredibly easy to set up thanks to its Intelligent Screen Adaption (ISA) technology that automatically focus the image and adjust the screen, and it can identify and avoid any obstacles between the projector and the screen to ensure the footage you're viewing is completely unobstructed.
During the Black Friday sales event, which runs from November 26 to November 30, the Elfin projector will have a huge 20% price cut to just $519, the lowest of the year.
Copy Of Dsc4772
Halo
Want a projector that will let you watch your media, any time, any place? The XGIMI Halo projector will be for you. Its 800 ANSI lumens brightness allows you to view your movies and TV shows at any time of day or night - even in bright sunlight at 1080p, offering a picture that is 225% clearer than mainstream 720p projectors.
With a built-in battery that can power images up to 150-inches for up to two hours, and dual 5W Harman Kardon speakers, this is also a projector you can take anywhere with you, and with Android TV 9.0, you can pick from thousands of apps with no need to hook anything up via wires.
This is truly the ultimate portable projector for those who are serious about outdoor watching, and during Black Friday, the Halo will have a big 20% price cut to $639, the lowest price of the year, between November 26 to November 30.
Mogo Bedroom
MoGo Pro and MoGo Pro+
Pair your Android smartphone or tablet with either the MoGo Pro and MoGo Pro+ and you'll have an ultra-portable cinema system that you can take with you anywhere you go.
The MoGo Pro offers a 1080p image at 300 ANSI lumens thanks to its advanced lamp, offering you detailed and vivid pictures up to 100-inches, with a built-in battery that can offer up two hours of big screen entertainment. Sound is provided by dual 3W Harman Kardon speakers, and Android TV offers you thousands of apps from the biggest media companies. With auto-focus and four-point keystone correction, you can set this projector up in a matter of seconds. Meanwhile, the MoGo Pro+ also offers 300 ANSI lumens brightness, which is far brighter than other projectors at this price point, and its automatic setup and built-in adjustable stand, allows you to get an awesome picture quickly and easily, no matter where you use it.
For Black Friday, the MoGo Pro gets a 20% discount to $399, the lowest price of the year, while the MoGo Pro+ gets 23% knocked off its price, down to $499, the lowest it's been all year, between November 26 to November 30.
