Will my Pixel 2 case fit on my Pixel 3?
Best answer: A Pixel 2 case will fit on the Pixel 3, but it's certainly not a perfect fit. It'll work in a pinch until your Pixel 3 case arrives, but it's not a long-term solution and it may scratch or scuff the Pixel 3 if you use it for a long time.
Amazon: Spigen Thin Fit ($12)
Only use as a temporary solution
It's pretty rare these days, but yes, the Pixel 2 and the Pixel 3 are similar enough in size and design for you to get away with using a Pixel 2 case on a brand new Pixel 3. It's not a precise fit, and a more rigid case is not going to fit as well as, say, the Google-made fabric case that has a bit of elasticity built into its design, but a Pixel 2 case can be fit onto the Pixel 3 for protection.
Of course, this should only be done as a temporary solution if your new phone arrives before you get a chance to pick out a case for it. We are not recommending buying a cheaper Pixel 2 case for your Pixel 3 to save money, as you're bound to find a comparable Pixel 3 case that's actually designed to fit the exact specifications of the newest Pixel. We've recommended a good case option from Spigen that's a better option than any Pixel 2 case in your drawer.
A great place to start
There are bound to be more great cases to come, but for now, we'll recommend this thin and reliable case option from Spigen.
Be an expert in 5 minutes
Marc Lagace was an Apps and Games Editor at Android Central between 2016 and 2020. You can reach out to him on Twitter [@spacelagace.
