Will any USB microphone work with a PlayStation 4?
Best answer: Any USB microphone will work with your PlayStation 4. You can use a USB headset or, if you are looking to stream your gaming, you can use a good desktop mic to give you the best sound possible.
- Cheap and awesome: BLU Snowball ($64 at Amazon)
- Black and red hotness: HyperX QuadCast ($140 at Amazon)
Why would you want a USB mic?
Traditionally you would use a microphone headset with a 3.5mm audio jack, plugged into your DualShock controller if you wanted to speak on game chat. That's fine, and it works perfectly well if you all you want to do is talk to your squadmates or talk smack to own the n00bs. However, if you are serious about your audio or you are streaming regularly, then a mic that's separate from your headphones makes a big difference.
When you are streaming your audio needs to be much better than average, and you can't be a mouth-breather. There is nothing worse than listening to a stream and hearing the sound of breathing, or the smacking of lips. This isn't ASMR, this is video game streaming and we want to hear what you are saying.
A mic like the BLU snowball will isolate the sound around you so that only the noise you want people to hear comes through. If you can spring for a little more, you can even get a pop shield and stand for your mic, making it sound even better.
What about headsets?
USB headsets tend to be much better than your normal 3.5mm jack connected ones. You might need a more expensive headset with an audio jack to get the same results as a cheap USB headset can provide. I prefer using a USB headset, mainly because I have to speak softly when I play and a USB mic seems to pick up my voice much better than one plugged into a jack.
Be an expert in 5 minutes
The downside is the cable. A USB mic has to be plugged into the PlayStation 4 and unless you are sitting at a desk or right in front of the PS4 you are going to encounter a length problem. I have yet to find a USB headset that had the cable length needed to play on my couch. As I said, if you are a streamer, you probably play at a desk so cable length likely won't be an issue, but for everyone else go for an external mic instead.
You know it's a gaming mic when it's black and red
The HyperX Quadcast is a USB mic to be reckoned with. It may be a little more expensive than we might like, but it does the job it is asked to do and it does it very well.
A brilliant entry level mic.
One of my favorite mics and perfect for someone just starting out. The BLU Snowball does a fantastic job of picking up only your voice and making sure it is crisp and clear.
Other accessories to help your audio
If you are really serious about your audio there are a few extras that will help elevate it. Things like pop filters and stands make a lot of difference to an audiophile.
Pemotech Pop filter ($10 at Amazon)
Perfect for the Hyper X Quadcast, this pop filter will help keep your P's, D's, and B's from blowing out peoples ear drums.
Neewer Mic boom ($13 at Amazon)
A could mic stand will help you easily position your mic so it is close enough to you for the audio to be good while keeping it out of your way while you play the game. No point streaming if you can't see the game to win!
AmazonBasics USB extension ($9 at Amazon)
If you really do have your heart set on a USB headset for your PlayStation 4 and you want to sit on the couch, then grab yourself an extension cord. It should work to extend your range, just watch out for interference that can happen in long cables.
