Is my appliance compatible with the Amazon Smart Plug?
Best answer: Probably. The Amazon Smart Plug was designed to work with most any product you have in your home but there are some exceptions and devices that shouldn't be connected.
Amazon: Amazon Smart Plug ($25)
Safety first
Before we dig in, know that the Amazon Smart Plug is designed for use with a 100-120 volt three prong system so it's a North American product only.
All electrical devices are designed with safety in mind and are rigorously tested to make sure the design works. All of us have probably plugged in one too many things on the same circuit and tripped a breaker or blown a fuse, and that's the first consideration you need to know about the Amazon Smart Plug — it has a safe output rating based on the type of load you're using. Here are the exact technical specifications according to Amazon.
Category | Specification |
Input | 100 - 120 VAC60 Hz15 Amp |
Output (resistive) | 120 VAC60 Hz15 Amp |
Output (inductive) | 120 VAC60 Hz10 Amp |
Output (motor) | 120 VAC60 Hz1/2 HP |
Output (incandescent) | 100 - 120 AC60 HzTV-5 |
The outlet on your wall is likely on a 15 amp circuit, so in many cases, the Smart Plug can handle as much power as the breaker or fuse can. To see what the power requirements of many electrical devices are and what type of load they create, you should visit Electrical Safety First. It's a site based out of the UK, but the power ratings for products are the same no matter which country you use them in and the charts here are an invaluable tool.
Specific exceptions
Be an expert in 5 minutes
- Amazon says that medical devices or any product that is required to be on 24/7 (through a backup battery source) should never be used with the Smart Plug. This makes sense as you wouldn't want a Wi-Fi glitch to cause something like an oxygen condenser to stop working.
- Never use the Amazon Smart Plug outdoors.
- Some devices that have their own mechanical on/off switch won't work with the Smart Plug because of logic attached to the inline switch. You can see the testing procedures to make sure your devices work at Amazon's device help pages for the Smart plug.
- Finally, devices that shouldn't be left powered on and unattended, like space heaters, should never be used with the Smart Plug. Again, you wouldn't want a Wi-Fi problem to be the cause of a fire.
It probably works
Chances are almost anything you would want to power on and off through a Smart Plug will work. Lights — whether incandescent, LED, or fluorescent — are compatible as long as they are standard devices intended for use in the home (something like a street lamp or traffic light probably won't work) and should work flawlessly. Audio-visual equipment should work provided it doesn't need a power cycle through the built-in switch, and other smart devices like cameras or home hubs should work just fine.
Just make sure everything is safe and properly grounded any time you're using electrical equipment and everything should be great. No more reaching behind the Christmas tree to unplug the lights at bedtime!
