Wield the right weapon with Razer's DeathAdder mouse down to $24
The Razer DeathAdder wired optical precision gaming mouse is down to $23.99 through Newegg Flash. This actually isn't the first time we've seen this deal. Newegg Flash offered it for a brief time earlier in September, but that price expired quickly. This one will, too, as the sale is only slated to last for two days anyway. Chances are it will sell out before then, too. When this mouse is sold elsewhere it goes for $40 or more. This is an older version of the DeathAdder, though, so you'll probably only find it on sale from third parties.
If you want a newer version of the DeathAdder you'll have to pay around $45, but maybe the more modern sensor is worth it for you. The original will not disappoint. There's a reason the DeathAdder is such a well-known name for gaming mice.
Razer Basilisk Ultimate wireless gaming mouse with RGB charging dock
$99.99 $140.00 Save $40
One of Razer's most comprehensive mice. Uses HyperSpeed tech so wireless feels as responsive as wired. Has a 20,000 DPI sensor with adjustable sensitivity. Customize the controls of the 11 buttons and the RGB lighting. 70-hour battery life.
Razer Viper Ultimate light wireless gaming mouse
$89.99 $110.00 Save $20
Has HyperSpeed wireless tech for extremely fast responsiveness that makes it feel like a wired mouse. Weighs only 74g so it moves easily. Has a 20,000 DPI sensor for precision that can be adjusted. Eight programmable buttons.
Razer DeathAdder v2 mini gaming mouse
$24.99 $50.00 Save $25
The grip tape gives you unprecedented control over the mouse even during fast-paced gaming. It also has an 8,500 DPI optical sensor with on-the-fly sensitivity adjustment. Use Razer Chroma for custom RGB lighting, too.
Razer Wolverine Tournament Edition gaming controller for PC and Xbox One
$79.99 $120.00 Save $40
Has a rapid-fire switch for instant actuation including a hair trigger mode to reduce the travel distance when pressing triggers. The four multi-function buttons can be remapped. Syncs with popular games and hardware including Razer gear.
Razer Opus active noise-cancelling Bluetooth headphones midnight blue
$149.99 $180.00 Save $30
The ANC in these headphones can detect and nullify incoming noise. They have a 25-hour battery life and are engineered for comfort that entire time with leatherette memory foam ear cushions and a well-balanced weight. Can go wired to save battery.
The DeathAdder is a wired gaming mouse that connects easily via USB, giving you the ability to plug and play with a variety of devices. It is designed for the right handed, so unfortunately my people of the left handed persuasion are out of luck. (If you are left handed and want a good recommendation of an older mouse, try the Mionix Avior 8200. It has been my go-to for years. Very comfortable in both the right and left hands.)
The mouse is equipped with a 3500 dpi precision sensor that uses infrared. It has 1,000 Hz ultrapolling and a 1 ms response time. You can adjust the sensitivity on the fly, and the five buttons are all individually programmable. It uses a braided fiber cable for durability as well. The mouse comes with a two-year warranty from Razer.
