Preserve your new Note 10 or Note 10 Plus with 10% off the Whitestone Dome Glass screen protector
The Samsung Galaxy Note 10 and Note 10 Plus smartphones are almost here. Are you planning on getting one? Keep your new, beautiful smartphone protected with the Whitestone Dome Glass tempered glass screen protector. You can pre-order the screen protector and get 10% off with code THRIFTERN10. This applies to both the Note 10 and the Note 10 Plus. The deal expires August 20.
The newest phone and the newest tempered glass screen protector. Name a more protective duo. I'll wait.
We know all about Whitestone Dome Glass. The company has made excellent screen protectors for basically every flagship Samsung smartphone for the last several generations. Watch Modern Dad's video on how well the screen protector worked for the Galaxy S10.
The screen protector uses a patended Liquid Optical Clear Adhesive designed to work with Samsung's ultrasonic fingerprint reader and provide edge-to-edge protection. It also comes with a limited lifetime warranty just in case. You'll also get an installation kit that includes an install frame and UV curing light so you can put the protector on without worrying about pockets of bubbles all over the place. Just take your time, do it right, and you'll ensure the best possible protection for your valuable new phone. If you're unsure whether you should get it or not, check out what Android Central users thought of the Whitestone on the Note 9.
