The white Anker Soundcore Liberty 2 Pro true wireless earbuds are down to $120
The Anker Soundcore Liberty 2 Pro true wireless earbuds are down to $119.99 with the $30 off on-page coupon at Amazon. We have seen the black version of these earbuds drop to around $110, but it looks like those earbuds are no longer available. And the white ones have never gone this low before. The earbuds normally sell for $150 and have gone for even more than that recently.
Anker Soundcore Life Q30 hybrid active noise-cancelling Bluetooth headphones
$59.99 $79.99 Save $20
These hybrid Bluetooth headphones reduce ambient noise up to 95% thanks to active noise-cancelling mics. The battery lasts up to 40 hours with ANC on or 60 hours with it off, and recharge via USB-C. Clip the $20 on-page coupon.
Anker Powerline II 6-feet USB-C to Lightning cable
$12.74 $15.00 Save $2
When using a USB-C power adapter (not included), you'll get the fastest possible charge for your iPhone. Plus you can seamlessly sync and charge your Mac. This is Apple MFi certified and lasts 12 times longer than other cables.
Anker Liberty Air 2 Pro true wireless earbuds Best Buy
$79.99 $130.00 Save $50
These earbuds have active noise-cancelling that's customizable with a simple app. You'll get a total of 26 hours of playtime with seven hours from a single charge and the rest from the charging case. Uses USB-C and has wireless charging.
Anker Soundcore Rave Neo portable Bluetooth speaker with LED lights
$84.99 $120.00 Save $35
Includes a rechargeable battery that will last for up to 18 hours and can charge other devices with the USB port. IPX7 rated for water resistance. The built-in LED lights will sync to the music you're playing. Connect multiple speakers together.
Anker Soundcore Liberty 2 Pro true wireless earbuds black
$49.99 $100.00 Save $50
They last for up to eight hours on a single charge with up to 32 hours total using the charging case. They have quick charge so you can get two hours after 10 minutes spent charging. They also charge via USB-C or a Qi wireless charger.
These earbuds have eight hours of playtime per earbud, and you can use the earbuds independently to extend that use. The charging case they come with adds another three full recharges before you ever need to plug into a wire to juice back up. With a quick charge of just 10 minutes inside the case you can get an extra two hours of playtime. Plus, the charging case can be recharged via USB-C or a Qi-compatible wireless charging pad, giving you plenty of options for keeping these batteries topped off. RAVPower has a wireless charging pad on sale for just $12.24 today you can use with these earbuds.
The Astria coaxial acoustic architecture helps eliminate interference and produces harmonized treble and bass for fantastic sound. The 11mm dynamic drivers support the immersive audio and create an expansive soundstage. The HearID technology inside the earbuds helps analyze your hearing profile and creates tailor-made sound just for you so anyone using these earbuds gets the perfect listening experience.
The earbuds also have microphones built in so you can use them to answer calls. The four mics combined with cVc 8.0 noise reduction technology helps ensure your voice stays crystal clear and no background noise interupts you.
Read more about the Soundcore Liberty 2 Pro in our review that gave them 4.5 stars out of 5 and a Recommended badge. Daniel Bader said, "The Liberty 2 Pro are an incredible pair of true wireless headphones that are easily worth their steep $150 asking price." Good thing they're cheaper now!
