Where to buy a Fitbit Inspire 2 replacement charger
Fitbit Inspire 2 Cradle 1
Fitbit Inspire 2 Cradle 1 (Image credit: Jeramy Johnson / Android Central)
Best answer: You'll have a few different choices when it comes to buying a Fitbit Inspire 2 replacement charger. You can buy one directly from Fitbit or you can explore some of the options from third-party sellers.
If you've dabbled with Fitbit fitness trackers at all, you're probably familiar with how the company is constantly changing its proprietary charging cables as time goes on. The Fitbit Inspire 2 is no exception to this unfortunate habit. If you previously owned the Fitbit Inspire or Inspire HR, you won't be able to use your old charger with the Inspire 2.
Article continues below
Considering that this fitness tracker offers a whopping 10 days of battery life on a single charge, you'll want to make sure you've got a charger around to take advantage of it. While you can always purchase one directly from the company, there are other options available to you as well.
It's important to keep in mind that the Fitbit Inspire 2 has only been on sale for a couple of months, which means that third-party options are still trickling in. As time goes on, more options will start to become available. The good news is that any of these will work and be able to charge your Fitbit Inspire 2.
Whether you've lost track of your original charger or you're planning ahead and want to have a backup option, there are some solid choices out there. No matter which one you pick, you'll be able to keep your fitness tracker charged with any one of these Fitbit Inspire 2 replacement chargers.
Courtney Lynch
Courtney Lynch is a freelance writer at Android Central. She's obsessed with all things health, fitness, and music. At any given time, she can be found checking out the latest and greatest gadgets while simultaneously petting her dog and sipping iced coffee.
