When your data must survive, grab this rugged 1TB portable hard drive down to $48
The Silicon Power Armor A30 1TB rugged portable hard drive is down to $47.99 on Amazon. These are sold by the manufacturer, Silicon Power. Considering they were going out of stock at one point, it's a safe bet the stock is limited for this deal. If you have any interest, I'd recommend going for it while you can. The hard drive has normally sold for around $57 or more, including a jump as high as $80 earlier this year.
You can also get the similar, but upgraded version, Armor A60 hard drive for around $49.99.
Silicon Power 4TB USB 3.0 military-grade portable hard drive
$116.67 $172.38 Save $56
$116.75 $172.38 Save $56
$119.99 $172.38 Save $52
$122.42 $172.38 Save $50
$125.09 $172.38 Save $47
The Armor A30 has a military-grade shock resistant design. The hexagonal pattern that covers the surface is also scratch resistant. You can see from the image how the design also incorporates some storage to carry the cables, adding a bit more portability to an already portable drive.
Get super fast data transfer speeds with USB 3.0. It's also backwards compatible with USB 2.0. The drive works on PC and Mac, and you can plug it into gaming consoles like the Xbox or PlayStation for extended storage. Silicon Power backs it up with a three-year warranty once you register your new device.
