What happens if I drop my Oculus Quest controller?
Best answer: The Oculus Quest Touch Controllers aren't as durable as previous models. There seems to be a particular weak point on the sensor ring. If you drop one or punch a wall while playing a game, there's a chance you'll crack it.
Not as durable
The Oculus Quest Touch Controllers are great at tracking hand movements, but they aren't as durable as previous Oculus Touch Controllers. There seems to be a design flaw that affects at least some Oculus Quest Touch Controllers. This fault could be limited to a subset of Touch Controllers, but users have reported cracked tracking rings on Reddit. In my time with the Oculus Quest I have accidentally hit a counter while playing the beta of Eleven Table Tennis and my Touch Controller was fine, but several users have dropped controllers that then cracked. Of course, it isn't a good idea to punch anything with them or to drop them, but accidents happen.
In the thread with the cracked controller, Oculus Support reached out and asked the user to report the case. There's a chance that it is a design defect that only affects some units.
Ordering a replacement
If you do crack a Touch Controller, you should contact Oculus Support. There's no guarantee that they'll replace it, but there's no harm in trying. Additionally, Oculus should know about controllers cracking so easily so they're aware of the issue and can fix it in the future.
If you do have to replace your Touch Controller, you can order them online. Oculus sells the left and right controllers separately on their website. A single controller costs $69. The website states that they'll be dispatched in around two days, so you probably won't have to wait very long to receive your replacement.
Sean Endicott
Latest in Virtual Reality
Vivo Vision Discovery Edition design reveal
This is Vivo's mixed reality headset
Samsung Project Moohan on display
Google ignored Android XR at GDC 2025, and indie VR devs are concerned
A panel of VR experts on stage at GDC 2025, discussing the "VR gaming visibility crisis."
Quest developers are joining forces to solve the 'VR visibility crisis'
A mockup of a mixed reality ornate ballroom with a Meta Quest 3. Ballroom made with Adobe AI
This new Meta Quest v74 feature is set to revolutionize immersive experiences
A promo image of the Meta Quest 3 on a grid background surrounded by eight bestselling VR titles in 2024, including Gorilla Tag and Batman: Arkham Shadow.
Meta's head of Oculus Publishing debunked Quest Store 'theories' and hinted at their Quest 4 audience at GDC
An official Gorilla Tag screenshot made to look like a "monke" is wearing a pink support headset
Gorilla Tag finally fixed its voice moderation problem
Latest in How-to
Testing Google Pixel 9's camera
Your Pixel 9 lets you connect to remote cameras and film content from different angles. Here's how
Notification Cooldown on Google Pixel
How to enable Notification Cooldown on a Google Pixel
A Google Pixel 9 Pro XL in the bootloader recovery menu.
The March Pixel update has been causing lots of headaches, but going back isn't easy
The Modes menu on a Pixel 9 showing Do Not Disturb turned on
Modes have replaced Do Not Disturb on your Pixel. Here's how to use them
Google Messages blue logo
How to automatically delete OTPs in Google Messages
Weather and Calendar in Morning Brief on Galaxy S25 Ultra
How to set up and use Now Brief on the Galaxy S25
