What Exercises can the Samsung Gear Fit2 Pro Track?
Best answer: The Samsung Gear Fit2 Pro natively tracks 17 different exercises, and there are thousands of third-party apps to help track everything it doesn't on its own.
Amazon: Samsung Geart Fit2 Pro ($149)
17 trackable exercises all in one place
From your Gear Fit2 Pro's home screen, you just have to swipe to find the Exercise app, find the exercise you want to track, and tap start. Here are all 17 exercises that the Gear Fit2 Pro currently tracks:
  • Running
  • Walking
  • Cycling
  • Hiking
  • Elliptical Trainer
  • Exercise Bike
  • Step Machine
  • Treadmill
  • Swimming
  • Lunges
  • Crunches
  • Squats
  • Star Jumps
  • Pilates
  • Yoga
  • Rowing Machine
  • Other Workout
What does each exercise entail?
In some cases, you'll have to do things a certain way for your Gear Fit2 Pro to track that specific exercise. Unsure on how to perform a particular exercise? You can actually get a demonstration of the correct action right on your Gear Fit2 Pro.
Don't see the exercise you want?
The Gear Fit2 Pro's exercise list is a good size, but it is missing some key workouts, like weight-lifting or specific sports, life golf.
If you want to track an exercise that isn't listed, you could use the "Other Workout" tracker. Or, considering the Gear Fit2 Pro is indeed a smartwatch, you could easily download a third-party app to track the exercises you want to do.
For example, there are swim tracking apps, tennis apps, golf tracking apps, and many more — over 3,000 in fact (including downloadable watchfaces).
Mick is a writer and duty editor for Android Central. When he's not on the job, he can usually be found vacuuming up pet hair or trying to convince his wife that he needs more guitars.
