What are the Visible APN settings for Android?
Best answer: Most of the time these settings will be automatically filled in during the setup process with the Visible app, but if you need to enter them manually confirm those details.
- Get pure Android unlocked: Google Pixel 3a ($400 at Amazon)
- A simple unlimited plan : Visible ($40/mo. at Visible)
Mostly, you'll use the app
Typically, your phone will set itself up when you insert the Visible SIM card and run the setup app. APN settings are used by the LTE data network to know exactly what service should be given to the phone. Something like this happens any time a device connects to the internet but with cell phone service, there's a bit more involved.
With a Visible SIM, once you insert the SIM card and go through the setup procedure in the Visible app, all connections should be automatically loaded. If not, you may need to enter them manually.
These are Visible's APN settings
You can find the APN settings in your phone's mobile network settings.
- Name: Visible
- APN: vzwinternet
- Proxy: Leave blank
- Port: Leave blank
- Username: Leave blank
- Password: Leave blank
- Server: Leave blank
- MMSC: http://mms.vtext.com/servlets/mms
- MMS proxy: 80
- MMS port: Leave blank
- MMS Protocol: Leave blank
- MCC: Leave blank
- MNC: Leave blank
- Authentication type: Leave blank
- APN type: default,supl,mms
- APN Protocol: IPv4
- APN roaming protocol: Leave blank
- APN enable/disable: Leave blank
Still having trouble?
If you're having connection issues, you should try contacting customer support through the app on a Wi-Fi connection. There may be a network wide issue or an easier solution. Sometimes resolving a connection issue can be as simple as restarting the device. In the worst case scenario, a factory reset on your phone will force all settings to reset and could resolve an issue if your software has become corrupted.
The pure Android experience
With one of the best cameras and pure Android, this phone works with nearly any carrier. This is one of the best devices supporting Visible's network.
Access Verizon's network for less
Visible is as simple as possible. Use Verizon's LTE network with no contract and get good speeds for browsing and streaming and no surprise fees.
Be an expert in 5 minutes
When Samuel is not writing about networking or 5G at Android Central, he spends most of his time researching computer components and obsessing over what CPU goes into the ultimate Windows 98 computer. It's the Pentium 3.
