Mobvoi TicWatch Pro 5 vs. Samsung Galaxy Watch 5 Pro
A battle of 'Pro' Wear OS smartwatches.
Best in class battery
The TicWatch Pro 5 won't let you down thanks to its 80-hours of battery life and ultra low-power display. Plus, Qualcomm's latest chip is incredibly powerful making for one of the best smartwatches out there.
For
- Secondary display adds even more battery life
- More RAM and storage
- Impressive performance
- Larger screen
Against
- No Google Assistant
- Limited third-party bands
- Only available in one size and color
Great but aging
The Galaxy Watch 5 Pro is a great smartwatch, but given that we're expecting a successor in the near future, you might be better off holding out or just grabbing the TicWatch.
For
- IP68 water and dust resistance
- Plenty of third-party bands to choose from
- Available with either Bluetooth and Wi-Fi or LTE
- Extra features for different workout types
Against
- An upgrade is likely around the corner
- Not as much RAM or storage
- Some features limited to Samsung phones
It took Mobvoi almost a year from the time when it initially teased the TicWatch Pro 5 to actually releasing it to the world. Meanwhile, Samsung is well-known for operating on a tight schedule, offering a new smartwatch on a yearly basis. But when it comes to comparing the Pro 5 to Samsung's Galaxy Watch 5 Pro, there are plenty of similarities to make you think twice about which smartwatch to get.
TicWatch Pro 5 vs. Samsung Galaxy Watch 5 Pro: Design and display
Without a doubt, both the TicWatch Pro 5 and Galaxy Watch 5 Pro are two of the largest smartwatches on the market today. The former comes equipped with a 1.43-inch OLED display complete with a 466 x 466 resolution. Meanwhile, the Galaxy Watch 5 Pro features a slightly-smaller 1.4-inch Super AMOLED display, with its defining feature being able to reach up to 1,000 nits of peak brightness.
When it comes to navigation, Mobvoi and Samsung took different approaches. Starting with the Galaxy Watch 5 Pro, Samsung removed the iconic rotating bezel from the Galaxy Watch 4 Classic and previous models. Instead, you can try your luck at scrolling through notifications with the touch-sensitive bezel. But even almost a year later, this isn't extremely reliable and you're better off just using the touch screen.
At first glance, you might think that the TicWatch Pro 5 has a rotating bezel, but instead, Mobvoi went the Apple Watch route with the rotating digital crown. You can still scroll through your apps and notifications using the touch screen, but the digital crown offers more fine-tune control when interacting with the watch.
One area where the Galaxy Watch 5 Pro excels is in the case size, as you can use most 20mm watch bands if you don't like the one that Samsung includes. Unfortunately, this isn't the case with the TicWatch Pro 5 due to its 24mm case size, and while there are some compatible watch bands out there, the 24mm watch band size is nowhere near as popular as the 20mm or even 22mm size.
TicWatch Pro 5 vs. Samsung Galaxy Watch 5 Pro: Specs, performance, and battery life
If you're wondering which of the best Android smartwatches is actually the more performant option, look no further than the TicWatch Pro 5. Mobvoi is using Qualcomm's latest Snapdragon W5+ wearable platform, which debuted in 2022. This is paired with 2GB of RAM and 32GB of storage, matching up with what is offered by the Pixel Watch.
What this means is ultra-fast and snappy performance, no matter what it is that you're trying to do. As noted in our review, the TicWatch Pro 5 didn't stutter once and has continued to be quite impressive, for the most part.
Header Cell - Column 0 | Mobvoi TicWatch Pro 5 | Samsung Galaxy Watch 5 |
Display | 1.43″ 466×466 OLED w/ Ultra low-power Display | 1.4″ Super AMOLED (330ppi) |
Material | Aluminum w/ high-strength nylon and fiberglass | Titanium |
Navigation | Touchscreen, rotating crown, one button | Touchscreen, two buttons, digital bezel |
Processor | Qualcomm Snapdragon W5+ Gen 1 | Exynos W920 |
Storage | 32GB | 16GB |
Battery | 628mAh; Up to 80 hours | 590mAh; Up to 80 hours |
Wireless Charging | Yes (proprietary) | Yes (Qi) |
Sensors | Accelerometer, Gyro Sensor, HD PPG Heart Rate Sensor, SpO2 Sensor, Skin Temperature Sensor, Low Latency Off-Body Sensor | Samsung BioActive Sensor (Optical Heart Rate + Electrical Heart Signal + Bioelectrical Impedance Analysis), Temperature Sensor, Accelerometer, Barometer, Gyro Sensor, Geomagnetic Sensor, Light Sensor |
Connectivity | Bluetooth 5.2, Wi-Fi, NFC | Bluetooth 5.2, Wi-Fi, NFC, LTE (optional) |
Compatibility | Android (Google Assistant) | Android (Google Assistant, Bixby) |
Protection | 5ATM, MIL-STD-810H | 5ATM, IP68, MIL-STD-810H |
Dimensions | 50.15 x 48 x 12.2mm | 45.4 x 45.4 x 15mm |
Weight (without band) | 44.35 grams (without band) | 46.5g |
Samsung's Galaxy Watch 5 Pro is powered by the company's Exynos W920 chip, which is paired with 1.5GB of RAM and 16GB of storage. While Samsung has done an excellent job with One UI 4.5 overall, you'll still occasionally run into some apps not opening immediately, and trying to move from one app to another can be slower than expected.
Without burying the lede, both of these smartwatches are incredible if you want a wearable with long battery life. Both Mobvoi and Samsung tout up to 80 hours on a single charge, a claim that each wearable comes pretty darn close to.
But the TicWatch Pro 5 has an extra trick up its sleeve thanks to its ultra-low-power display. When enabled, this presents a bunch of information on your screen, including the time, steps, heart rate, and more. So if you run out of juice, you won't just be wearing an oversized bracelet, compared to many other smartwatches.
TicWatch Pro 5 vs. Samsung Galaxy Watch 5 Pro: Software and future updates
Out of the gate, both the TicWatch Pro 5 and Galaxy Watch 5 Pro are powered by Wear OS 3, but with a catch. Mobvoi's software interface more closely resembles what you would find on something like the Pixel Watch, with a few tweaks made here and there, along with some of Mobvoi's own apps. Of note, both watches do support Google Pay, which is a plus when you forget your wallet!
As you might suspect, the Galaxy Watch 5 Pro is running a modified version of Wear OS 3, courtesy of One UI 4.5. This pretty much just gives you the "Samsung-ifcation" of Google's wearable platform, while still being reminiscent of Tizen OS from a few years ago. No matter which watch you choose, there's nothing fundamentally wrong with either option.
Instead, you might be concerned about future Wear OS versions coming to the TicWatch Pro 5, as evidenced by the company's continued delays in bringing Wear OS 3 to previous iterations. Samsung, on the other hand, has already announced One UI 5 for the Galaxy Watch 4 and Watch 5, along with releasing a beta program.
Mobvoi's commitment to future updates isn't quite a deal breaker for the TicWatch Pro 5, but it's definitely something to keep in mind.
TicWatch Pro 5 vs. Samsung Galaxy Watch 5 Pro: Which should you buy?
It would be easy to sit here and just tell you to go get the TicWatch Pro 5. It's less expensive, includes an incredible ultra-low-power display, and offers better performance than the Galaxy Watch 5 Pro. Throw in the fact that Samsung is expected to launch its next lineup of wearables alongside the Galaxy Z Fold 5 and Flip 5, and it's a more difficult decision.
However, something to remember is Samsung's track record in recent years when it comes to software updates for its phones, tablets, and wearables. Wear OS 4 might not seem like a game-changer, but you can rest easy knowing that the Galaxy Watch 5 will get it.
With that in mind, we are still recommending the TicWatch Pro 5 over the Galaxy Watch 5 Pro, and you definitely won't regret picking one up.
The TicWatch Pro 5 offers a no-compromises approach to enjoying a Wear OS 3 smartwatch. It sports an excellent feature-set along with a few unique features you won't find anywhere else.
The Galaxy Watch 5 Pro is likely going to be the default wearable for many, but you should probably think twice before springing for one.
Be an expert in 5 minutes
Andrew Myrick is a Senior Editor at Android Central. He enjoys everything to do with technology, including tablets, smartphones, and everything in between. Perhaps his favorite past-time is collecting different headphones, even if they all end up in the same drawer.
finbaar I bought my son the TicWatch Pro 3 recently as it was very cheap to pick up. I was very impressed about the low power screen, this seemed a great way to extend the use of a watch even if you lose power for the "smarts". Also the performance of the W4100 was fine and the new silicon in the Pro 5 is obviously even better. Therefore I am tempted to get the Pro 5 and move away from the Huawei watch I'm currently using.Reply
