Garmin Instinct 3 vs. Fenix 8: Not really a fair fight
If you're looking for the most features, the Fenix 8 is the clear winner.
A value pick
Garmin's Instinct 3 comes in both AMOLED and MIP Solar variants, and packs an ultra-rugged design. For around $500, you get many of the bare essentials, but not all of them. A few adventure watch staples, like offline maps, LTE connectivity, or a touchscreen, aren't available here. With that being said, it's still a solid midrange fitness watch.
For
- More affordable than Garmin Fenix 8 or Enduro 3
- AMOLED display is an upgrade over Instinct 2 models
- Excellent battery life
Against
- No touchscreen
- No GPX exports or offline maps
- Last-generation heart rate sensor
The complete package
Garmin's Fenix 8 is a smartwatch that has all the features you'd need (or want) plus outstanding battery life. It has an AMOLED touchscreen display, a brand-new Garmin heart rate sensor, and more. There isn't LTE support, unfortunately. You'll also have to pay a pretty penny for all these features.
For
- Bright AMOLED touchscreen
- Garmin's best training features and accurate sensors
Against
- No LTE support
- Extremely expensive
- Lacks a killer new feature
Garmin recently refreshed both its Instinct and Fenix product lines with new offerings, and they've immediately become two of the best long-lasting sports and adventure watches available. The Garmin Instinct 3 and Fenix 8 can be found in multiple case sizes and AMOLED or MIP/Solar configurations, so there's almost certainly a style that meets your needs between them.
When considering the Instinct 3 or Fenix 8, the decision comes down to a single question: is the Fenix 8 worth double the price of the Instinct 3? On paper, the premium Garmin Fenix 8 handily outdoes the midrange Garmin Instinct 3, but that doesn't necessarily mean it's the better value. Let's break down exactly how these two great Garmin smartwatches compare, and who they're each made for.
Garmin Instinct 3 vs. Fenix 8: Design and display
The Garmin Instinct 3 and Fenix 8 are both rugged watches built for the outdoors, but the latter features a more premium design. The Instinct 3 uses a mix of fiber-reinforced polymer and aluminum, giving it a softer, rubber or silicone-like texture. Meanwhile, the Fenix 8 uses a steel or titanium construction with Gorilla Glass or sapphire cover glass.
Both watches have a 10ATM water-resistance rating, with the Fenix 8 taking that a step further with dive capabilities and a MIL-STD-810H certification — a military-grade durability standard. As a result, the Fenix 8 is heavier, with the steel variant weighing 74 grams and the titanium option weighing 64 grams. The Instinct 3 weighs just 59 grams by comparison.
Garmin ships the Instinct 3 and Fenix 8 with silicone bands by default, but they each can be configured with nylon and leather straps instead. The Fenix 8 also has a metal band option available, which could dress the steel or titanium chassis up for special occasions.
The Garmin Fenix 8 is available in more case sizes, starting at 43mm and topping out at 51mm. There's also a 47mm configuration right in the middle. Garmin sells the Instinct 3 in two size options: 45mm and 50mm. You'll see a 43mm Instinct watch on Garmin's website, but that's the Instinct E, a cheaper watch with a completely different feature set.
Garmin Instinct 3 vs. Fenix 8: Hardware and features
Garmin's Fenix 8 has better hardware and more software features than the Instinct 3, full stop. It starts with the display, where the Fenix 8 uses a 1.3-inch or 1.4-inch AMOLED panel compared to the Instinct 3's 1.2-inch AMOLED panel. As previously mentioned, there are MIP options that tend to look worse than AMOLED and are less responsive, but offer longer, "unlimited" battery life with solar charging.
We don't know which processor powers the Fenix 8, but the Instinct 3 is powered by the ARM Cortex M4. The Instinct 3's lowly processor, paired with its comical 17MB of RAM and up to 4GB of onboard storage, is the reason why it doesn't support many software features. It can't save offline maps, and you may find yourself needing to delete or offload saved workouts just to install updates because the storage threshold is so tight.
Category | Garmin Instinct 3 | Garmin Fenix 8 |
Display | 1.2-inch (390x390) AMOLED | 1.3-inch (416x416) or 1.4-inch (454x454) AMOLED |
Colors | Black, Twilight, Neo Tropic, Electric Lime | Sapphire, Titanium, Sapphire, Carbon Gray DLC Titanium, Slate Gray |
Processor | ARM Coretex M4 | Unknown |
RAM & storage | 17MB + 4GB | 1GB + 32GB |
Battery | 45mm: 18 days / 7 AOD; 50mm: 24 days / 9 AOD | 43mm: 10 days / 4 AOD; 47mm: 16 days / 7 AOD; 51mm: 29 days / 13 AOD |
Software | Garmin OS | Garmin OS |
Sensors | HR, SpO2, skin temp, accelerometer, altimeter, compass, gyroscope | Garmin Elevate v5 HR, SpO2, ECG, skin temp, accelerometer, altimeter, ambient light, compass, depth, gyroscope |
Connectivity | Bluetooth, ANT+, NFC, multi-band GPS | Bluetooth, ANT+, WiFi, NFC, multi-band GPS |
Durability | 10 ATM, Chemically Strengthened Glass, fiber-reinforced polymer/aluminum | 10ATM with leakproof buttons; EN13319 (40m diving standard); MIL-STD-810H (thermal, shock, water); Gorilla Glass (steel) or sapphire glass (titanium) |
Weight | 59g | Stainless Steel: 74g, Titanium: 64g |
Price | $499.99 | $1,199.99 |
The Fenix 8 gives you a lot more to work with, featuring 1GB of memory and 32GB of storage. That's plenty to store workouts, offline maps, music, and more. It also has Wi-Fi support, but otherwise matches the Instinct 3 in terms of connectivity. Both watches support Bluetooth, ANT+, NFC for Garmin Pay, and multi-band GPS.
The differences start to come in the hardware health sensors, starting with the heart rate sensor. The Instinct 3 uses the same, older sensor as the Instinct 3. The Garmin Fenix 8 is equipped with the latest Garmin Elevate v5 sensor, which is more accurate and adds an ECG function. For what it's worth, while the Elevate v5 sensor is more consistent, our reviewer found the Instinct 3 reaches the same average BPM as a good armband monitor.
Plus, GPS accuracy is on par with the Fenix 8, so not everything on the Instinct 3 is a downgrade. With that being said, the Fenix 8 just has so many more software features, including a rucking mode, offline maps, estimated hydration and electrolyte loss widgets, dive capabilities, ski maps, strength training tools, and the fully featured Garmin Coach.
It's impossible to ignore the fact that the majority of Fenix 8 features are available on the Garmin Forerunner 965, which isn't as rugged as the Instinct 3 but still offers up to 23 days of battery life.
Garmin Instinct 3 vs. Fenix 8: Which one should you buy?
Arguably, the only reason the Garmin Instinct 3 can challenge the Fenix 8 is due to the AMOLED upgrade this year. It's still not a touchscreen, so you'll need to fiddle with clunky buttons to navigate Garmin OS at times. However, the screen is beautiful and bright, and fun color combinations help the Instinct 3 add to its sporty look. With plenty of health sensors and basic Garmin training features, the Instinct 3 does give you almost everything you need.
Certain things, like the lack of offline maps, GPX exports, and a touchscreen, are going to leave some adventurers wanting more. To get those features, you're looking at the $900 Enduro 3 or the $1,100 Fenix 8. As for whether the Garmin Fenix 8 is worth more than double the price of the Instinct 3, that's for you to decide. If you're someone who regularly pounds the pavement or the trails, or is a multi-sport athlete, I could definitely see the appeal.
For most of us, the Instinct 3 is hands-down the better value. But if you have high training demands and a lot of cash, it's hard to look past the Fenix 8's enticing features.
The midrange option
Not everyone needs the absolute best. The Garmin Instinct 3 is for people who want a rugged and long-lasting adventure watch without spending a fortune. As long as you usually have your phone nearby when you're out and about, you won't notice many of the Instinct 3's shortcomings.
The absolute best
Need all the top Garmin features, plus outstanding battery life, and are willing to pay a premium for all of it? The Garmin Fenix 8 should be your pick. It's one of the best adventure watches on the market, and represents Garmin's top offerings.
Be an expert in 5 minutes
Brady is a tech journalist for Android Central, with a focus on news, phones, tablets, audio, wearables, and software. He has spent the last three years reporting and commenting on all things related to consumer technology for various publications. Brady graduated from St. John's University with a bachelor's degree in journalism. His work has been published in XDA, Android Police, Tech Advisor, iMore, Screen Rant, and Android Headlines. When he isn't experimenting with the latest tech, you can find Brady running or watching Big East basketball.
