Best Fitbit Charge 6 bands 2025
Take a look at some of the finest bands for your new Fitbit.
The Fitbit Charge 6 includes quite a few improvements and new features in comparison to its predecessor. However, one thing that thankfully hasn't changed is band compatibility, as Fitbit's new activity tracker works flawlessly with all the bands intended for the last-gen Fitbit Charge 5 model.
This means that if you're planning to buy the new Fitbit wearable, you'll have a whole lot of the best Fitbit Charge 6 bands from which to choose. Here are some great options (both official and third-party) that we've rounded up to make things easier for you!
Check out the best Fitbit Charge 6 bands you can get
Best overall
Made from high-quality elastomer TPU, Maledan's sports bands are perfect for your Charge 6. They're skin-friendly and feature multiple perforations for easier ventilation, as well as a double metal buckle that ensures a secure fit around the wrist. They're available as multipacks, each having three bands in a variety of colors. It's the best option if you're looking for something third-party.
Best first-party band
It doesn't come cheap, but Fitbit's very own accessory band is worth the price. Made from Horween leather tanned in Chicago, it develops an aged patina finish over time that looks awesome. The band is handcrafted using premium oils and dyes, and it's also quite lightweight. It comes in basic black making it the ideal back-up band.
Best value pack bands
As far as bang-for-buck products are concerned, this one takes the cake. Witzon's multi-pack offers 15 (yes, you read that right!) silicone bands in an assortment of colors for your Charge 6, at an insanely good price. The bands are comfortable to wear and come with a 'pin-and-tuck' closure that makes it harder for them to get caught on things.
Best thin bands
The thin design of Surundo's sports bands not only makes for all-day comfort, but also gives your Charge 6 a different overall aesthetic. They're made with eco-friendly, waterproof materials, and don't irritate your skin either. The integrated 'loop and peg' closure is simple yet secure and allows for easy adjustment as per your wrist size.
Best nylon bands
Stylish yet durable, Haveda's Charge 6 bands are ideal for wrists of all sizes. They're made from braided nylon that's comfortable on the skin, and also wicks away moisture from sweat and water. You also get loop buckles and velcro fasteners for a snug fit at all times, and the bands are washable, too. They're available as three-item packs in a variety of color choices.
Best premium band
Classy yet convenient, the hook & loop accessory band is one of the best first-party Fitbit Charge 6 offerings out there. Thanks to an easy binding fastener and integrated plastic loop, it's super simple to put it on and take if off your wrist: there's no need for clasps or buckles! The band is made from nylon and contains nine percent recycled polyester, with the heathered pattern making for a plush, textured feel.
Most stylish band
Surundo's Milanese loop band transforms your Charge 6 from a fitness gadget to a fashion accessory. It's made from top-quality stainless-steel that's both luxurious and durable. The polished edges and woven mesh design enhance the style quotient even further, while the magnetic buckle keeps the band and tracker securely fastened around your wrist at all times.
Best woven band
Fitbit's official woven band isn't just good for your Charge 6, it's good for the planet as well. The accessory is made from a textile material — named 'REPREVE' by the company — which includes up to 96 percent recycled plastic yarn. The sustainable product sports an aluminum buckle and a plastic connector and comes in a funky design that makes a statement.
Best leather band
Made from premium soft leather and with a stainless-steel polished buckle, Fintie's offering belies its affordable price tag. The band is lightweight and comfortable enough to be worn all day. It has plenty of holes that allow for granular adjustment for nearly all wrist sizes. It comes with quick-release spring bars and two strap holder loops.
Spruce up your Fitbit Charge 6 with these bands
As we found in our review of the Fitbit Charge 6, the fitness tracker is a worthy upgrade to the previous-generation model. In fact, it even ranks as one of the new best fitness trackers available in the market.
Although it doesn't look too different from 2021's Fitbit Charge 5, there are changes both on the inside and the outside. The Charge 6 comes with a physical side button for easier navigation, as well as advanced sensors that should allow for much more accurate readings. Since Fitbit has been a part of Google for quite some time, we also get features such as YouTube Music Controls and turn-by-turn navigation using Google Maps.
These are all exciting upgrades, so if you're planning on buying Fitbit's latest activity tracker, we suggest checking out these best Fitbit Charge 6 bands to go along with it.
Our top vote goes to Maledan's excellent sports bands, which are available in packs of three at a very reasonable price. They're made from a skin-friendly elastomer TPU material and come with a double metal buckle for a secure fit. You also get sweat and water resistance and a variety of funky color options.
If you're a fan of official accessories, we recommend taking a look at Fitbit's Horween leather band. No doubt it's expensive, but then, it's also a handcrafted product that'll continue to look great even after it ages over time. We also like Haveda's offerings a lot, as they're immensely comfortable. The braided nylon material and velcro straps make for a snug fit, while also being easier to clean and maintain.
For all its new improvements, Fitbit Charge 6 remains backward-compatible with the last-gen model's bands. So, if you want even more choice, we suggest checking out the best Fitbit Charge 5 bands as well.
Be an expert in 5 minutes
When Rajat got his first Personal Computer—a Pentium III machine with 128MB of RAM and a 56kbps dial-up modem—back in 2001, he had little idea it would mark the beginning of a lifelong love affair with gadgets. That fascination, combined with a penchant for writing and editing, ultimately led to him becoming a technology journalist. Some of his other interests include Photography, Hand Lettering, and Digital Typography. Rajat is also somewhat obsessed with wrist-worn timepieces and appreciates a Casio just as much as a Jaeger-LeCoultre.
