The water-resistant XSound Go Bluetooth Speaker falls to $22 at Amazon
You don't have to buy a brand name speaker to score great sounding audio. The Tribit XSound Go portable Bluetooth speaker is on sale at Amazon today for just $22.39 when you first clip the coupon on its product page and then use promo code KBPYCM7E during checkout. That saves you nearly $11 off its usual price there, though only the black version of this speaker is available for today's discount.
This portable Bluetooth speaker packs in surprisingly loud sound with crystal clear highs, crisp mids, and a rich bass to keep you jamming anywhere you bring it. It's equipped with bass radiators and dual 6W drivers, though a more exciting feature is its waterproof design. You can use this speaker by the pool or even in the shower without worry. It's pretty sleek too with curved edges and a matte finish. There's a built-in carrying strap as well.
Any portable Bluetooth speaker you buy should be able to last at least half a day if not longer. Luckily, the rechargeable battery inside the XSound Go keeps it powered for up to 24 hours on a single charge. The speaker uses Bluetooth 4.2 to wirelessly connect with devices and has a range of up to 66 feet.
Using this speaker's integrated multi-function button, you can even access your phone's smart assistant such as Siri or Google Assistant. You can take calls with its built-in microphone too, without even needing your phone around to make it happen.
Shipping at Amazon is free on orders totaling $25 or more, or with an Amazon Prime membership. If you've never been a Prime member before, you can start a free 30-day trial to score free two-day shipping with no order minimum, access to the Prime Video streaming service, exclusive members-only discounts, and more.
Be an expert in 5 minutes
