Upgrade to 4K with Vizio's 65-inch smart TV on sale for $550 with a $150 Dell gift card
You are now subscribed
Your newsletter sign-up was successful
The Vizio E65-F0 65-inch 4K smart TV is down to $549.99 at Dell and several other retailers including B&H. The difference is at Dell you also get a $150 gift card whereas the other retailers don't include anything close to that bonus. The TV normally sells for $700 or more, but since it's a 2018 model everyone is trying to clear some shelf space.
The Vizio comes with 4K resolutions, support for HDR10, HLG, and Dolby Vision, and a 120 Hz effective refresh rate. You'll get tons of connectivity options, including built-in Chromecast, Wi-Fi, and Ethernet. Connect it to your Amazon or Google smart hub to control the TV with your voice. Ports include USB and four HDMI. You'll also get a one-year warranty.
Dell's gift cards are very specific. They can only be spent at Dell.com, you will be emailed the code within 20 days of your purchase, and you have 90 days to use it before it expires. Spend it before it expires! Try upgrading your audio with a sound bar or speakers, or spend it on something else entirely.
