Visible vs. Cricket Wireless: Which is better for you?
Visible is still the best value in prepaid unlimited.
Two great unlimited options
Owned by Verizon, Visible keeps things as simple as they can be with just two unlimited plans. The base unlimited plan is a great pick for most people, thanks to its low price and even unlimited hotspot data. On the other hand, Visible Plus is a solid upgrade with international perks and Ultra-Wideband connectivity. The pricing starts at $25/month, and the prepaid carrier often runs deals to sweeten the deals even further.
For
- Verizon's LTE and 5G networks
- Unlimited data on both plans
- Unlimited mobile hotspot data at 5Mbps
- International features like texting available with Visible+
- Premium 5G data available with Visible+
Against
- No multi-line savings
- No domestic roaming can lead to rural dead zones
Lots of features for less
Cricket Wireless offers flexibility with its four different plans and reliable coverage on AT&T's networks. You can save a lot by bringing multiple lines to the 10GB and unlimited plans up to a maximum of five lines. The top unlimited plan offers premium data, 15GB of hotspot usage, 150GB of cloud storage, and even ad-supported Max that lets you stream your favorite TV shows and movies. All other plans come with 2GB of cloud storage.
For
- AT&T's LTE and 5G networks
- Unlimited calling and texting on all plans
- Multi-line discounts
- Ad-supported Max bundled with the highest plan
- Free cloud storage included with all plans
Against
- 5G connectivity limited to the slower nationwide network
- No hotspot on base and multi-month unlimited plans
Trying to decide between Visible vs. Cricket Wireless can be confusing. Both are low-cost, prepaid wireless carriers that leverage their larger networks to give subscribers affordable and reliable service. Cricket Wireless uses AT&T's networks, while Visible uses Verizon's networks. These two carriers trade blows when it comes to coverage, especially in rural areas, but most people should have no issues with coverage on either.
Cricket's offerings are laid out similar to those of other operators, with four primary plans. The three larger plans are eligible for multi-line discounts. Cricket also has two unlimited plans and supports nationwide 5G, but only the more expensive unlimited plan comes with premium data and hotspot usage.
Visible, on the other hand, offers more with its two simple plans. The base option's well-suited to those looking for cheaper unlimited data without needing the fastest speeds out there. Then there's Visible Plus, which comes with faster 5G and 50GB of premium data, which make it a good pick for those in congested areas or users who just want to make the most of a new 5G plan.
- MVNO deals: Mint Mobile | Visible | Boost | Tello | Cricket
Visible vs. Cricket Wireless: What kind of service do you need?
Visible keeps things very simple, but its choices may be lacking for those looking for some something smaller or wanting to bring the whole family along. Visible has no multi-line discounts, so there's no incentive to bring your whole family. If you're just looking for service for yourself, it's a great option, but if you've got a whole family to get connected, you won't find any discounts.
Cricket Wireless has a more traditional layout of plans, with four main plans starting with 5GB or 10GB of data. The 10GB plan also gets minor multi-line discounts and an auto-pay discount. Moving up to unlimited plans, the cheaper unlimited plan is likely going to be the sweet spot for many families that need a lot of data but want to save on service.
Header Cell - Column 0 | Visible | Cricket Wireless |
Base network | Verizon | AT&T |
International calling | Yes (Visible+) | Yes (for an extra $5 per month) |
Domestic roaming | No | Yes |
Mexico and Canada Data | Yes (Visible+) | Included with Cricket More and Cricket Core Unlimited plans |
Hotspot data | Unlimited (capped at 5Mbps) | 15GB with Cricket More Unlimited plan |
5G access | Yes | Nationwide 5G on all plans |
Video stream quality | 480p (SD) | 480p (SD) |
Cricket also allows you to roam in Mexico and Canada for up to 50% of your usage. If you're a frequent traveler or have family/friends abroad, this is definitely something you might be interested in. It's also important to note that Cricket's prices drop when you add more lines, making it almost as affordable (though still more expensive) as Visible.
Unlimited talk and text to Mexico and Canada is included with both Visible plans, but you only get data roaming and international perks with Visible Plus.
Visible vs. Cricket Wireless: Visible's plans
Visible offers two plans but sticks to unlimited everything on both. What separates them are data priority and international features. Visible's base plan is most similar to the old plan we tested in our Visible review, though responsiveness may be a bit better thanks to a change in how Visible devices connect to the Verizon network.
The base Visible plan comes with unlimited talk, text, and data including hotspot use at 5Mbps. You can connect to 5G though your speed will be limited as compared to Verizon's postpaid plans or Visible Plus. For most people, however, Visible still has plenty of speed for just about anything. Visible also includes calling to Mexico and Canada with the base plan.
If you're looking for a bit more, Visible Plus unlocks 5G speeds with Ultra-Wideband support and even comes with 50GB of premium data to keep your speeds up when network congestion is high. You get the same 5Mbps hotspot usage as the base plan, however. International features get a big upgrade with Visible Plus adding in usage in Mexico and Canada, calling to 30+ countries, and texting to 200+ countries.
Header Cell - Column 0 | Visible | Visible+ |
Data | Unlimited | Unlimited (50GB premium data) |
5G access | Nationwide | Nationwide and Ultra-Wideband |
Hotspot data | Unlimited (5Mbps) | Unlimited (5Mbps) |
Spam protection | Yes | Yes |
Price | $25 per month | $45 per month ($35 for limited time) |
Visible vs. Cricket Wireless: Cricket's plans
Cricket Wireless uses AT&T's huge 4G LTE and 5G networks with four plans available. The two base data plans come with 5GB and 10GB data. One thing to keep in mind is that the 10GB plan gets multi-line and auto-pay discounts that the 5GB plan doesn't. If you get three lines, the cost ends up being the same for 5GB and 10GB. Even more interestingly, though, at three lines, you could go up to the Unlimited Core plan for the same price.
If you want to get the most out of Cricket Wireless, Unlimited More (also known as Unlimited + 15GB Mobile Hotspot Data on their website) plan is the way to go. It's a bit pricey at $60 per month for a single line, but the price comes down pretty quickly with multiple lines. Still, with this plan, your data is upgraded to premium, meaning it will take priority over other Cricket customers. You also get 15GB of hotspot data to share with other devices. Last but not least, this plan comes with ad-supported HBO Max and 150GB free cloud storage. All other plans offer 2GB free cloud storage.
Category | Cricket More | Cricket Core | Cricket 10GB | Cricket 5GB |
Data | Unlimited (premium) | Unlimited | 10GB | 5GB |
Hotspot | 15GB | Add-on available (10GB for $10) | None | None |
Mexico and Canada Usage | Included | Included | Only with new accounts | None |
International text | 37 countries | 37 countries | With additional fee | None |
5G access | Nationwide 5G | Nationwide 5G | Nationwide 5G | Nationwide 5G |
Streaming resolution | 480p | 480p | 480p | 480p |
Extras | HBO Max (with ads) & 150GB cloud storage | 2GB cloud storage | 2GB cloud storage | 2GB cloud storage |
Single line price | $60 | $55 | $40 | $30 |
Four-line price (per line) | $33 | $25 | $28 | $30 |
You should check Cricket's coverage map to make sure if it will work in your area, though each Cricket plan comes with roaming. This is especially useful if you travel frequently. If you travel abroad, there are clear advantages to both unlimited data plans (Cricket More and Cricket Core), including unlimited international texting to 37 countries and service in Canada and Mexico—although Canada usage must be less than 50 percent of overall usage.
There's no denying that Visible is one of the best MVNO carriers available today. With Verizon's network, unlimited data, 5G connectivity, and unlimited hotspot use, it's hard to beat even its basic plan. Visible is one of the best values for those looking for a single line, and it gets even better with Visible Plus. With Visible Plus filling the premium gap for the carrier, you can decide if you can get by on Visible's basic plan or want some of the best speeds of the Verizon network with Visible Plus.
Ultimately both carriers are strong choices, but when it comes to saving money and unlimited data, Visible comes out on the top. Cricket's top plan is worth it if you're looking for a family plan and can sign up for at least two lines. This brings the cost down to $45 per month, or as low as $33 per month if you have four lines. It's a good deal but still pricier than Visible.
Unlimited everything
Visible's two plans offer a price and feature set that makes a lot of sense for most smartphone users. While it lacks family plan savings, Visible is still among the most affordable prepaid carriers around. Considering that you get unlimited data, hotspot usage, and even some international features in the price, it's hard to beat.
A unique plan for everyone
Cricket has a plan for everyone, starting with its most basic 5GB plan. Its top plan offers unlimited data, 5G connectivity, mobile hotspot usage, and international service, though it might not be worth it unless you sign up for multiple lines. But no matter which plan you choose, you'll have the benefit of AT&T's wide coverage and access to roaming.
Be an expert in 5 minutes
When Samuel is not writing about networking or 5G at Android Central, he spends most of his time researching computer components and obsessing over what CPU goes into the ultimate Windows 98 computer. It's the Pentium 3.
- Patrick FarmereCommerce Editor
