Record every moment with Vantrue's N2 Pro dash cam at over 30% off
The Vantrue N2 Pro 1440p dual dash cam drops to $135.99 on Amazon when you enter promo code VANTRUER during checkout. Without the code, the dash cam sells for $200. You're saving $65 and getting it for way lower than any direct price drop we've ever seen.
This is a dual dash cam capable of capturing both the road ahead of you and the inside of your car. The front-facing camera can record in 1440p at 30 frames per second or 1080p at 60 fps. Other features include a 170-degree wide angle lens, 24-hour parking monitor, night vision, motion detection, and a Time Lapse function that lets you control changes over a long period of time.
Remember dash cams like this one needs to use microSD cards to record footage onto. It supports cards up to 256GB so grab at least one or stock up on a couple while you can.
