Use Bluetooth in your car with Anker's discounted FM Transmitter and USB Charger for just $12
Driving a car nowadays without Bluetooth functionality is strange. Nobody wants to be subjected to the same 12 songs on the radio all the time. Take advantage of empty stations with the Anker Roav SmartCharge F0. This multipurpose gadget usually sells for around $17, but clipping the on-page coupon today will drop your cost down to just $11.69 via Amazon. This is nearly the best deal we've ever shared for this product.
You can score free shipping by either spending at least $25 or by using Amazon Prime. Amazon's free standard shipping deadline to receive your order by December 24 is today, so if you're looking at this item as a potential gift for the holidays, don't delay completing the purchase!
Anker Soundcore Life Q30 hybrid active noise-cancelling Bluetooth headphones
$59.99 $79.99 Save $20
These hybrid Bluetooth headphones reduce ambient noise up to 95% thanks to active noise-cancelling mics. The battery lasts up to 40 hours with ANC on or 60 hours with it off, and recharge via USB-C. Clip the $20 on-page coupon.
Anker Powerline II 6-feet USB-C to Lightning cable
$12.74 $15.00 Save $2
When using a USB-C power adapter (not included), you'll get the fastest possible charge for your iPhone. Plus you can seamlessly sync and charge your Mac. This is Apple MFi certified and lasts 12 times longer than other cables.
Anker Liberty Air 2 Pro true wireless earbuds Best Buy
$79.99 $130.00 Save $50
These earbuds have active noise-cancelling that's customizable with a simple app. You'll get a total of 26 hours of playtime with seven hours from a single charge and the rest from the charging case. Uses USB-C and has wireless charging.
Anker Soundcore Rave Neo portable Bluetooth speaker with LED lights
$84.99 $120.00 Save $35
Includes a rechargeable battery that will last for up to 18 hours and can charge other devices with the USB port. IPX7 rated for water resistance. The built-in LED lights will sync to the music you're playing. Connect multiple speakers together.
Anker Soundcore Liberty 2 Pro true wireless earbuds black
$49.99 $100.00 Save $50
They last for up to eight hours on a single charge with up to 32 hours total using the charging case. They have quick charge so you can get two hours after 10 minutes spent charging. They also charge via USB-C or a Qi wireless charger.
Anker's Roav SmartCharge takes your car's cigarette lighter outlet and turns it into a veritable powerhouse. The device is a Bluetooth FM transmitter, so it takes your phone's signal and transmits it over an empty radio station. You can use an app like Clear FM to find a suitable station wherever you're at. No more obnoxious radio ads or chattering hosts. You'll be able to play whatever you want, whether it's an audiobook or your favorite Spotify playlist. You can also use the SmartCharge F0 to take hands-free calls, and its noise-suppressing mic ensures that whoever is on the other end will be able to hear you clearly.
The device is also a car charger. It features two USB-A ports with high-speed PowerIQ charging to ensure that connected devices are topped up quickly and safely. You won't have to deal with overheating, excessive current, or any other nonsense. Customers have left the product with 4.4 out of 5 stars based on an average of nearly 3,100 reviews.
Now that you have yourself a smart car charger, you should consider adding some dedicated cables to your vehicle so that you always have a way to power up your stuff. Both Lightning cables and USB-C cables are up for grabs at a discount today.
