Upgrade your home theater with a refurb ViewSonic projector as low as $160
Check out Woot's limited-time sale on refurbished ViewSonic projectors. The sale is ongoing until Oct 16 or until everything sells out, which is far more likely. It includes 17 different projectors that range from prices as low as $159.99 to as much as $899.99. When you consider the $899.99 projector sells for around $2,300 brand new, that's some killer savings. They all seem to come with a 90-day warranty from ViewSonic, too.
Woot's limited-time sale includes almost 20 different models with varying feature sets. Some are HD, some are 4K, and some are designed to be ultra portable. All are refurbished and come with a 90-day ViewSonic warranty.
ViewSonic VX2768-2KP-MHD 27-inch 1440p 144Hz IPS gaming monitor
$279.99 $315.00 Save $35
Has 2560 x 1440 pixel resolution, an ultra-fast 1ms response time, and a 144Hz refresh rate. Perfect stats for any gamer. AMD FreeSync and Nvidia G-Sync compatibility reduces screen tearing. Includes custom visual modes for different games.
ViewSonic XG2405 24-inch 1080p 144Hz IPS gaming monitor
$179.99 $220.00 Save $40
The specs for this screen include a 1920 x 1080 pixel resolution, a 144Hz refresh rate, and a 1ms response time on an IPS panel. Also has AMD's FreeSync tech to reduce screen tearing. Features a frameless design, solid stand, VESA mounting, and more.
ViewSonic VX2758-P-MHD 27 Inch Frameless 1080p 144Hz 1ms Gaming Monitor with FreeSync Eye Care HDMI and DisplayPort
$219.99 $300.00 Save $80
ViewSonic XG2401 24-inch 1080p 144Hz gaming monitor
$206.98 $199.99 Save $-7
ViewSonic PS501W 3400 Lumens WXGA HDMI Short Throw Projector for Home and Office
$499.95 $749.00 Save $249
The least expensive option is the ViewSonic M1 at $159.99. It's an ultra portable LED projector. It uses a shorter throw lens to project up to 100 inches at a resolution of 854 x 480. It includes dual Harman Kardon speakers, a built-in battery that provides up to six hours of portable power, and a USB-C port for charging mobile devices. Has other connectivity options, too, including HDMI.
The ViewSonic LS820 projector for $899.99 can project in full 1920 x 1080 HD resolution up to 150 inches with 3500 lumens. It's super powerful and uses ViewSonic's exclusive SuperColor tech for a wide color gamut. So you end up with great image production that can be reproduced no matter where you're projecting. Thanks to the short throw lens you don't have to move the projector very far away to get a huge image, either. It's compatible with PCs, Macs, mobile devices, and more.
There are tons of other options in this sale, too. Want 4K? Try the ViewSonic PX727. It's down to $599.99. Want a projector that's eco-friendly and doesn't require a cool down period to be moved? Grab the ViewSonic PJL7211 for $189.99. Whether you're looking to upgrade your own theater at home or need something to use for presentations at work or school, Woot's sale has you covered. Just find the one that fits best for you.
