Turn your Google Home Mini portable with 20% off the Kiwi Design Battery Base
Ever wish you could bring your Google Home Mini around with you? The Kiwi Design Rechargeable Battery Base was designed exclusively for that purpose, so you can unchain your Google Home Mini speaker and transform it into a portable version. Though it regularly sells for $30, today you can pick one up in either Dark Gray, Orange, or Light Stone Gray for just $23.99 when you clip the coupon on Amazon's product page. These colors match the Charcoal, Coral, and Chalk versions of the Google Home Mini really nicely, though you might find a cool combination by picking a color that's different from whichever Google Home Mini you own.
Kiwi Design's Rechargeable Battery Base lets you bring your Google Home Mini just about anywhere. It even acts as a case to protect the bottom and sides of the speaker, and since it's rubberized, it helps minimize impacts and vibrations. It's easy to put on and remove whenever, too. With its built-in carrying strap, you can find tons of ways to hang it or clip it from various places.
The Battery Base is equipped with a 7800mAh battery that can last for up to 12 hours of on-the-go listening time. Of course, many of the features of the Google Home Mini won't work without a Wi-Fi connection, so you'll want to make sure you can connect to Wi-Fi wherever you bring it. There are also four LED battery indicator lights which show you the base's battery level at a glance.
Kiwi Design includes a one-year warranty with the Battery Base's purchase. You will not be able to use it with any smart speaker other than the Google Home Mini, so make sure you're prepared with one at home before the base arrives.
Amazon offers free shipping on orders totaling $25 or more, or with Amazon Prime. If you don't want to try a free 30-day Prime trial, adding this $2 carabiner to your cart will get your order shipped for free. That's cheaper than paying for shipping on the base itself, and then you'll have a way to clip it to your backpack or somewhere else easily.
