Turn one outlet into four with this discounted iClever USB Wall Charger
You are now subscribed
Your newsletter sign-up was successful
Charging multiple devices can be tricky. When your phone, tablet, smartwatch, and on-the-go console all use different cords, it's annoying to prioritize their charging needs. Take care of the issue with the iClever 4-Port USB Wall Charger on sale for $14.99. All you have to do is enter code 58M9ITOX during checkout to get in on this price, which saves you $5 off the normal cost. It hasn't dropped this low directly in over a year but this coupon will only remain valid for a limited time.
iClever 61W Power Delivery 3.0 USB-C Wall Charger
$15.35 $26.99 Save $12
iClever 10W Qi-compatible wireless car charger with automatic clamp
$24.14 $37.00 Save $13
Stack the coupon code with the on-page coupon for maximum savings. Includes automatic infrared sensor that detects phone and works even when the car is off. Compatible with all Qi-enabled wireless charging phones and provides up to 10W power.
This well-rated charging station has SmartID technology built in, which provides optimal speeds to all of your devices, up to 2.4 amps per port. There are safeguards against short-circuiting, overheating, and overcharging, too. The plug folds down for easy transportation as well, making it the perfect travel plug. The manufacturer backs this product with an 18-month warranty and a 30-day money-back guarantee.
It's worth noting that the iClever charger does not support Qualcomm Quick Charge 3.0. Whether or not you need that will depend on what phone you have. If it's something you deem necessary, it's worth checking out the discounted AMLINK 40W USB Wall Charger. It has three USB-A ports, one of which is QC 3.0-enabled, as well as a USB-C port. It currently has an on-page coupon that will save you a couple of bucks.
