Whether you're simply bored at home and want to improve your movie viewing experience, or you want to upgrade your setup so you can enjoy The Falcon and the Winter Soldier in all its glory over the next several weeks, you ought to check out this one-day sale on Anker Nebula projectors.
Over at Amazon, these popular projectors have had prices cut by as much as 30%, dropping them down to record lows. The deals expire tonight or when sold out, so don't miss them.
Anker Soundcore Life Q30 hybrid active noise-cancelling Bluetooth headphones
$59.99 $79.99 Save $20
These hybrid Bluetooth headphones reduce ambient noise up to 95% thanks to active noise-cancelling mics. The battery lasts up to 40 hours with ANC on or 60 hours with it off, and recharge via USB-C. Clip the $20 on-page coupon.
Anker Powerline II 6-feet USB-C to Lightning cable
$12.74 $15.00 Save $2
When using a USB-C power adapter (not included), you'll get the fastest possible charge for your iPhone. Plus you can seamlessly sync and charge your Mac. This is Apple MFi certified and lasts 12 times longer than other cables.
Anker Liberty Air 2 Pro true wireless earbuds Best Buy
$79.99 $130.00 Save $50
These earbuds have active noise-cancelling that's customizable with a simple app. You'll get a total of 26 hours of playtime with seven hours from a single charge and the rest from the charging case. Uses USB-C and has wireless charging.
Anker Soundcore Rave Neo portable Bluetooth speaker with LED lights
$84.99 $120.00 Save $35
Includes a rechargeable battery that will last for up to 18 hours and can charge other devices with the USB port. IPX7 rated for water resistance. The built-in LED lights will sync to the music you're playing. Connect multiple speakers together.
Anker Soundcore Liberty 2 Pro true wireless earbuds black
$49.99 $100.00 Save $50
They last for up to eight hours on a single charge with up to 32 hours total using the charging case. They have quick charge so you can get two hours after 10 minutes spent charging. They also charge via USB-C or a Qi wireless charger.
The sale features the diminutive Nebula Capsule at just $221.99, a discount of 26% and a match for the lowest we've ever seen it go at Amazon.
Nebula's miniature offering and features a lightweight and compact design. Despite being the size of a soda can, it packs in a 100 lumen HD projector capable of producing a clear image up to 100-inches in size and a 360-degree speaker.
Running Android 7.1, it can also stream directly from services like Netflix and YouTube or you can use your smartphone or computer to mirror content to the Capsule wirelessly or using its HDMI input. It has a 4-hour battery life and features Quick Charge 2.0 to get it back to full power as fast as possible.
Other options include the Nebula Solar projector which is seeing a $120 price cut and a new all-time low price. We reviewed it, giving it 4 stars out of 5, stating that it offers "almost everything you could want from an all-in-one portable projector".
The Nebula Cosmos is also on sale at $559.99 — 30% off. It offers the brightest image of the bunch with 900 ANSI lumens and can project up to 120 inches in size. The 4K version is not in the one-day sale but does have a coupon for $200 off on its product page.
Be an expert in 5 minutes
