TP-Link's Deco M5 system is $40 off today only at Woot
You are now subscribed
Your newsletter sign-up was successful
If you experience a weak Wi-Fi signal in certain areas of your home, you could likely benefit from replacing your router with a mesh Wi-Fi system like TP-Link's dual-band Deco M5. It utilizes multiple units which work together to expand your network's wireless coverage while keeping your internet signal strong and stable, and for larger homes you can add on more units as needed.
Right now, Woot is offering the three-piece Deco M5 kit for $139.99. That saves you $40 off its usual price at Amazon, though there is a coupon there taking $20 right now. Regardless, this is one of the best deals we've ever seen on this three-pack; a single Deco router goes for $69 so you're essentially getting the third unit for just a couple of bucks. Shipping is free if you log in with an Amazon Prime account, or it's an extra $6.
TP-Link Archer AX3000 Wi-Fi 6 wireless router
$99.00 $130.00 Save $31
Wi-Fi 6 promises speeds up to three times faster than previous generations with four times the bandwidth capacity and 75% lower latency. The router has MU-MIMO tech to cover multiple devices connected at once and Ethernet for wired connections.
TP-Link Kasa KP400 smart outdoor plug 2-pack
$29.99 $50.00 Save $20
Get free shipping with your Prime membership. Each plug has two outlets that can be controlled together or individually. Use your phone or voice control with Google Assistant or Amazon Alexa to control them from anywhere. Weather resistant.
TP-Link Archer A20 AC4000 Tri-Band Wi-Fi router
$139.99 $200.00 Save $60
With a tri-band radio, MU-MIMO technology, Beamforming, link aggregation, and more, this router is perfect for homes with a dozen different devices all trying to connect at once. It supports Windows, Mac, and Linux. Includes a 2-year warranty.
$16.99 $25.00 Save $8
With two outlets you can control two outdoor devices either together or individually. And you can do it from anywhere using your phone or voice control through Google Assistant or Amazon Alexa. Weather resistant with long Wi-Fi range.
TP-Link Archer C7 AC1750 Wi-Fi 5 dual-band router
$49.99 $80.00 Save $30
This great little budget router is capable of data transfer speeds up to 1750 Mbps with 2.4GHz and 5GHz wireless bands. Also has four Ethernet ports for a wired connection. Includes a quick and easy setup wizard.
The Deco M5 replaces your Wi-Fi router and any other devices you've been using to make up for dead zones like range extenders. The three-pack on sale today is capable of covering up to 5,500 square feet of your home with Wi-Fi, and you can buy more Deco units to extend its range at any time. TP-Link HomeCare gives the system security, while adaptive routing technology lets it choose the fastest path to keep your network running smoothly. With the TP-Link Deco app, all you have to do is follow the on-screen instructions to get the system up and running as soon as possible. TP-Link covers the Deco M5 with a two-year warranty.
At Amazon, almost 1,300 customers left a review for the Deco M5 resulting in a rating of 4.5 out of 5 stars.
