TP-Link's N300 Wi-Fi range extender helps fill in dead zones and has dropped to just $14
Having trouble keeping a stable connection to your Wi-Fi network at home? The TP-Link N300 Wi-Fi extender can help change that, and today it's on sale for just $13.99 when you clip the $3 off on-page coupon at Amazon. We shared a deal on this range extender about two months ago when it dropped to around $15, but today's the lowest we've seen. It sells for just under $20 on average and is an inexpensive way to enhance your internet connection without buying an entirely new router.
TP-Link Archer AX3000 Wi-Fi 6 wireless router
$99.00 $130.00 Save $31
Wi-Fi 6 promises speeds up to three times faster than previous generations with four times the bandwidth capacity and 75% lower latency. The router has MU-MIMO tech to cover multiple devices connected at once and Ethernet for wired connections.
TP-Link Kasa KP400 smart outdoor plug 2-pack
$29.99 $50.00 Save $20
Get free shipping with your Prime membership. Each plug has two outlets that can be controlled together or individually. Use your phone or voice control with Google Assistant or Amazon Alexa to control them from anywhere. Weather resistant.
TP-Link Archer A20 AC4000 Tri-Band Wi-Fi router
$139.99 $200.00 Save $60
With a tri-band radio, MU-MIMO technology, Beamforming, link aggregation, and more, this router is perfect for homes with a dozen different devices all trying to connect at once. It supports Windows, Mac, and Linux. Includes a 2-year warranty.
$16.99 $25.00 Save $8
With two outlets you can control two outdoor devices either together or individually. And you can do it from anywhere using your phone or voice control through Google Assistant or Amazon Alexa. Weather resistant with long Wi-Fi range.
TP-Link Archer C7 AC1750 Wi-Fi 5 dual-band router
$49.99 $80.00 Save $30
This great little budget router is capable of data transfer speeds up to 1750 Mbps with 2.4GHz and 5GHz wireless bands. Also has four Ethernet ports for a wired connection. Includes a quick and easy setup wizard.
The N300 uses your 2.4GHz Wi-Fi band to extend a weak wireless signal in a spot of your home that might not get any at all. It has a limitation of 300Mbps but something is better than nothing, and this is designed to work with pretty much any standard router or gateway. It has an Ethernet port you can use to directly connect to the device for something slightly more stable. It comes with a two-year warranty. More than 18,000 users have tried it out and give it 3.8 stars overall.
Be an expert in 5 minutes
