TP-Link's Kasa KL130 smart bulb on sale for $20 can change colors with your voice
The TP-Link KL130 Kasa multi-color dimmable smart LED A19 light bulb is down to $19.99 at Newegg with code EMCTCTW32. The smart bulb has been selling for around $30 at most retailers since May. It was selling as much as $40 before that. Recently it dropped to $25 in a lot of places, including Amazon. Newegg's just sweetening the pot with the code that takes an additional $5 off the price.
TP-Link Archer AX3000 Wi-Fi 6 wireless router
$99.00 $130.00 Save $31
Wi-Fi 6 promises speeds up to three times faster than previous generations with four times the bandwidth capacity and 75% lower latency. The router has MU-MIMO tech to cover multiple devices connected at once and Ethernet for wired connections.
TP-Link Kasa KP400 smart outdoor plug 2-pack
$29.99 $50.00 Save $20
Get free shipping with your Prime membership. Each plug has two outlets that can be controlled together or individually. Use your phone or voice control with Google Assistant or Amazon Alexa to control them from anywhere. Weather resistant.
TP-Link Archer A20 AC4000 Tri-Band Wi-Fi router
$139.99 $200.00 Save $60
With a tri-band radio, MU-MIMO technology, Beamforming, link aggregation, and more, this router is perfect for homes with a dozen different devices all trying to connect at once. It supports Windows, Mac, and Linux. Includes a 2-year warranty.
$16.99 $25.00 Save $8
With two outlets you can control two outdoor devices either together or individually. And you can do it from anywhere using your phone or voice control through Google Assistant or Amazon Alexa. Weather resistant with long Wi-Fi range.
TP-Link Archer C7 AC1750 Wi-Fi 5 dual-band router
$49.99 $80.00 Save $30
This great little budget router is capable of data transfer speeds up to 1750 Mbps with 2.4GHz and 5GHz wireless bands. Also has four Ethernet ports for a wired connection. Includes a quick and easy setup wizard.
The multi-color bulb has access to the full color spectrum with millions of colors and hues to choose from. Once you install it and connect to your 2.4GHz Wi-Fi, you can also connect to your smart home network. You don't need a separate hub or extra hardware, just the Kasa app for your phone. You'll be able to control all the smart functionality from the app, but you can also use voice commands through Amazon Alexa, Google Assistant, or Microsoft Cortana.
