Costco members can get the TP-Link Deco M9 Plus Wi-Fi system on sale for $220
If you're a Costco member, you can save $100 on the 3-pack of the TP-Link Deco M9 Plus tri-band mesh networking Wi-Fi system. That brings the total cost down to $219.99 from $320. The 2-pack commonly sells for around $210 at retailers like Walmart, so you're basically just paying another $10 for a third satellite you can use to extend the system even farther.
TP-Link Archer AX3000 Wi-Fi 6 wireless router
$99.00 $130.00 Save $31
Wi-Fi 6 promises speeds up to three times faster than previous generations with four times the bandwidth capacity and 75% lower latency. The router has MU-MIMO tech to cover multiple devices connected at once and Ethernet for wired connections.
TP-Link Kasa KP400 smart outdoor plug 2-pack
$29.99 $50.00 Save $20
Get free shipping with your Prime membership. Each plug has two outlets that can be controlled together or individually. Use your phone or voice control with Google Assistant or Amazon Alexa to control them from anywhere. Weather resistant.
TP-Link Archer A20 AC4000 Tri-Band Wi-Fi router
$139.99 $200.00 Save $60
With a tri-band radio, MU-MIMO technology, Beamforming, link aggregation, and more, this router is perfect for homes with a dozen different devices all trying to connect at once. It supports Windows, Mac, and Linux. Includes a 2-year warranty.
$16.99 $25.00 Save $8
With two outlets you can control two outdoor devices either together or individually. And you can do it from anywhere using your phone or voice control through Google Assistant or Amazon Alexa. Weather resistant with long Wi-Fi range.
TP-Link Archer C7 AC1750 Wi-Fi 5 dual-band router
$49.99 $80.00 Save $30
This great little budget router is capable of data transfer speeds up to 1750 Mbps with 2.4GHz and 5GHz wireless bands. Also has four Ethernet ports for a wired connection. Includes a quick and easy setup wizard.
The Deco M9 Plus is TP-Link's most powerful mesh networking system. You'll be able to cover up to 6,500 square feet in Wi-Fi. The tri-band speeds up to AC2200 have a dynamic backhaul that can support up to 100 devices. With the Deco M9 Plus's intelligent network, you'll be able to move throughout your home with just a single Wi-Fi name and password without worrying about your connection as you switch devices. The Deco M9 Plus is also unique in the Deco lineup in that it's the only one with a built-in smart hub that can control ZigBee, Bluetooth, and Wi-Fi smart home products.
Be an expert in 5 minutes
