Best Samsung Galaxy S6 cases
We all have different needs to be met, but there are particular covers out there that stand out among the rest, providing both quality protection and exceptional design.
After careful consideration and input from members of the Galaxy S6 forums, we've selected cases that have made the biggest impression. These choices aren't limited by their size, manufacturer or price — only tried and true options that keep your Galaxy S6 safe from the inevitable drop.
- OtterBox Defender Series Case
- OtterBox Commuter Series Case
- Ringke Slim Case
- Urban Armor Gear Composite Hybrid Case
- Spigen Slim Armor Case
- Speck CandyShell Grip Case
- Spigen Neo Hybrid Case
- Obliq Thin Bumper Case
- Verus Card Case
- Supcase Unicorn Beetle PRO
- Caseology Wavelength Series Case
First up, we have the OtterBox Defender Case for the Galaxy S6. Easily the most rugged of the bunch, this hybrid case comes loaded with 3 layers of protection along with a tough belt-clip holster to keep on your belt or pocket. Its size isn't meant for everyone, but those who do use it are keeping their Galaxy S6 safe from the worst impacts.
Speaking of its size, the Galaxy S6 OtterBox Defender is actually the slimmest version we've seen to date, and that's really saying something. You've still got all the familiar features of the Defender series, including an interior foam that seats your device safely, port covers to keep out dirt and other debris, an exterior slipcover that helps absorb impacts while enhancing your grip around the case, topped with a high-impact polycarbonate shell that keeps it all together.
Let's not forget the built-in screen protector, either — great for shielding against those pesky scratches. The Defender's holster holds the Galaxy S6 with the case on, allowing quick and easy access when you need answer a call, text or email while you're out and about. Many users opt out of utilizing the holster, but it's definitely handy for certain occasions.
The slimmer option of the OtterBox series is the Commuter Case, providing just about everything you'd need to protect your Galaxy S6 from scratches, drops and dirt intrusion.
Be an expert in 5 minutes
Surprisingly lightweight for its design, the Commuter Case features a smooth polycarbonate shell on top of a shock absorbing silicone interior that slides together for a compact fit. It comes with port covers pre-installed to keep out dust and other debris, but are able to be permanently removed if they're more annoying than useful.
With this hybrid case around your Galaxy S6, you can enjoy an enhanced grip thanks to the skinned edges and easy-press side buttons. It comes in black, blue or glacier color combinations and even includes a self-adhesive screen protector.
Ringke Slim Case
There's always a total transparent option that makes it to the top of the list, and the Ringke Slim Case is ranked most popular this time around. And, if clear's not your thing — there are 6 other colors to choose from.
Perfect for slim, casual protection, this clear cover keeps bulk out of the equation and the good looks of the Galaxy S6 in. There's complete access to the side buttons, ports, camera and display while the case is worn, too. Included with the Ringke Slim Case is a complimentary HD film for shielding the back and front of your Galaxy S6 from unwanted scratches — so that's a plus.
Keep in mind, however, that you're not getting a huge amount of protection with this case. It's slim, yeah, but when it comes to more serious impacts — don't expect a whole lot. For everyday use and minor drops it'll do the job, though.
If you're into rugged looks, the Composite Hybrid Case from UAG Read our hands-on review is definitely worth considering. Don't be put off by its damage-resistant design, though, because it's actually slim for the level of protection it provides. Both the TPU and polycarbonate shell are fused together with extra impact protection around all 4 corners.
There's obviously a lot to grip with the Composite Hybrid Case, between the TPU side grips and busy pattern on the back shell — dropping your Galaxy S6 becomes a rare occasion. There aren't any port covers to get in the way, but the case meets military drop-test standards — including a screen protector to ward off any scratches.
This case comes in some pretty cool color options, too. Solid colors include: black, white, rust and slate — for more transparency, there's ice and ash.
An all-around favorite is Spigen's Slim Armor Case, sporting dual layers in an incredibly low profile. It's no secret that Spigen has been at the forefront of the popularity list for quite some time now, and for good reason. They're consistent with their quality and design, offering options for both heavy duty and average users.
What's great about the Slim Armor Case is its ability to shield against impacts without bulking up the Galaxy S6 to the point that it's no longer attractive. It leaves precision cutouts for everything you'd need, including the camera, flash and ports. The side buttons are raised for a more uniformed look, and are easy to press.
On the back shell is a fold-out kickstand for convenient viewing when you need it, and it doesn't protrude from the rest of the case like we've seen with the Trident Kraken AMS. It's designed to allow you to face your Galaxy S6 down on any flat surface while elevating the display, keeping away any possible scuffs or scratches. The Slim Armor Case comes in gunmetal (as shown), metal slate, shimmery white, and blue topaz.
Speck's CandyShell Grip is back by popular demand with the Samsung Galaxy S6. It's got serious grip, and we can't blame users for enjoying that level of security.
Featuring an easy, snap-on installation the CandyShell Grip Case provides a soft, rubbery interior that keeps your Galaxy S6 safe from wear. Each corner has been reinforced to help handle impacts if and when they occur, while the raised bezel keeps the display from touching flat surfaces.
The polycarbonate shell is glossy, so fingerprints and smudges can be an issue over time, but are easily manageable. The most notable feature of the CandyShell Grip is its rubber stripes that wrap from side to side, enhancing grip in the most important areas. The symmetrical pattern has a unique look, too. If the black and grey (pictured) isn't your style, choose from 5 other color combinations.
Sporting excellent grip with its textured TPU skin is Spigen's Neo Hybrid Case for the Galaxy S6. This slim cover combines a thin polycarbonate bumper with a shock absorbent skin that's design to keep things slim yet protective. Metal coated buttons along the sides add to the case's good looks, too. Bumper colors include slate, gold, blue, and silver.
This slim bumper case for the Galaxy S6 is designed to offer easy installation and removal while keeping you safe against minor impacts. The back cover rocks a brushed aluminum finish that looks amazing around the Galaxy S6 in any color. Ports and buttons are left open for easy access as well. Take your pick from 7 different color combinations.
Verus Card Case
Who says a wallet case has to be a flip cover? The Verus Card Case for Galaxy S6 features a dual-layer design that provides optimal protection against impacts while adding storage under the shell for your personal items. Keep your ID, credit card, even some cash in your new case by sliding it open when you need. Available colors include silver, red, yellow, gold, and dark silver.
The next best thing to an OtterBox is the Unicorn Beetle for Galaxy S6. This rugged case turns your device into a beast that's ready for anything. Between the textured exterior shell, built-in screen protector, and shock absorbent skin inside, impacts don't stand a chance in damaging your Galaxy S6. Also included is a rugged belt holster for keeping your protected device at your side. The Unicorn Beetle comes in black, blue, green, pink, and white.
If you're after grip, then Caseology's Wavelength Case for Galaxy S6 is right up your alley. This incredibly slim cover utilizes both polycarbonate and TPU materials to handle impacts. The grippy "wave" patterned skin on the back is what makes this case stand out. Choose from a handful of different color combinations to find the Wavelength that suits you and your Galaxy S6 best.
Which is your favorite case?
How do you keep your Galaxy S6 protected? Let us know in the comments!
Marc Lagace was an Apps and Games Editor at Android Central between 2016 and 2020. You can reach out to him on Twitter [@spacelagace.
