Top 10 Smart Home Accessories To Buy With Amazon Echo Dot
Amazon Echo Dot 3rd Gen
Amazon Echo Dot 3rd Gen (Image credit: Russell Holly / Android Central)
The Amazon Echo Dot alone is a pretty unassuming product, but it's all you really need to control many different smart home products using just your voice. We've rounded up the ten best smart home accessories to buy with your Amazon Echo Dot.
Build out the smart home of your dreams
It's pretty incredible how many cool smart home products work well with Alexa, but the most useful accessory on our list is not much more than custom-fitted plastic. There's something brilliant about the TotalMount wall mount for the Echo Dot. It lets you get your smart speaker up off the countertop and mounted near an outlet on a wall, which helps ensure Alexa always clearly hears you.
There are some really cool Amazon products for entertaining or even feeding yourself, like the Amazon Smart Oven that will automatically order popcorn when you're running low. This smart appliance features Alexa integration and is a breeze to set up and use.
Article continues below
Another great place to start is with a starter kit of smart bulbs. Sengled's two-bulb starter kit is a great place to start because Sengled's bulbs are top quality. Once you've got that hub, it's easy to add extra bulbs, and you can get an 8-pack of soft white smart bulbs for the price of less than $10 a bulb which is an absolute steal of a deal.
Marc Lagace
Marc Lagace was an Apps and Games Editor at Android Central between 2016 and 2020. You can reach out to him on Twitter [@spacelagace.
