This tiny, surge-protecting USB power strip is nearly 30% off at Amazon
If your workstation could use a few more ports to power your devices up, the Xcentz Power Strip Surge Protector Cube could be just the thing you need, Luckily, today it drops to $16.99 at Amazon when you enter promo code XCENTZS101 during checkout. That saves you $7 off its regular cost there, and gives you the opportunity to pick it up at one of the best prices we've ever seen it reach.
This compact power strip is built into a cube to keep it tiny, which means it's a great travel charger, too. It's equipped with four surge-protected AC outlets and three USB charging ports featuring smart IC technology that offers an optimized charge per device. Meanwhile, its fire-retardant casing and overload protection help keep you and your tech safe while the power strip cube is in use. It comes with an extra long cable to make sure there are no issues getting it to reach onto your desk or nightstand. Plus, Xcentz includes an 18-month warranty with today's purchase.
Having a power strip like this comes in handy when you need enough room to power up more than one or two devices, though you could also benefit from picking up a surge protector which features smart functionality. They're not too expensive anymore, and our guide to the best smart surge protectors in 2019 has two options which are even more affordable than the power cube above and have the ability to be controlled using an app on your smarthphone.
Shipping at Amazon is free on orders totaling $25 or more, or with an Amazon Prime membership. If you've never been a member before, consider starting a free 30-day trial today to see how it is, score free two-day shipping with no order minimum, exclusive members-only discounts, and more.
Be an expert in 5 minutes
