TicWatch Pro 3 vs. TicWatch Pro (2020): Should you upgrade?
TicWatch Pro 3
Mobvoi has a winner with the TicWatch Pro 3. It's got fantastic performance from the Snapdragon 4100, improved and added health sensors, and the body of the watch has been trimmed down. If you like the TicWatch Pro 2020, the Pro 3 is an instant upgrade.
TicWatch Pro 3
Perfomance king
TicWatch Pro (2020)
When the TicWatch Pro 2020 got its upgrade to 1GB of RAM, it made a world of difference. Though it's still great when compared to older devices, it doesn't hold a candle to the Pro 3. The dated 2100 processor chugs for basic tasks, and the heavy chunky watch feels like a rock in comparison.
TicWatch Pro (2020)
A solid option
With Mobvoi's most recent flagship entry into the Wear OS smartwatch realm, it's worth taking a look at the newest TicWatch Pro 3 vs. TicWatch Pro (2020). Though the latter has the 2020 moniker, the Ticwatch Pro 3 is the latest and greatest from the smartwatch maker. It's the first to run the Qualcomm Snapdragon 4100 processor, but does this upgrade over the 2100 SoC really make a difference, and is that all that's to the Pro 3?
TicWatch Pro 3 vs. TicWatch Pro (2020): It's about more than just silicon
Previously, Mobvoi merely swapped out the processor and called it an upgrade, as was done when the first TicWatch Pro bumped up to 1GB of RAM and became the Pro (2020). In contrast, the Pro 3 is a complete overhaul.
Header Cell - Column 0 | TicWatch Pro 3 | TicWatch Pro 2020 |
Price | $300 | $260 |
Dimensions | 47x12.2mm | 45mmx12.6mm |
Weight | 42g | 58g |
Watch Band size | 22mm | 22mm |
Material | Stainless steel+Plastic | Stainless steel+Plastic |
Battery | 577mAhSmart Mode up to 72 hoursEssential Mode up to 45 days | 415mAHSmart Mode up to 48 hoursEssential Mode up to 30 days |
Display | 1.4" AMOLED RetinaLCD FSTN | 1.39" AMOLEDLCD FSTN |
Colors | Shadow Black | Shadow BlackLiquid Silver |
Memory | 1GB RAM8GB ROM | 1GB RAM4GB ROM |
Processor | Qualcomm Snapdragon 4100 | Qualcomm Snapdragon 2100 |
Water and Dust resistance | IP68swimming suitable | IP68Military Standard 810G |
Connectivity & Sensors | Bluetooth 4.2 & BLENFCGyroscopeBarometerSpO2Heart RateAmbient Light SensorAccelerometer | Bluetooth 4.2NFCGyroscopeHeart RateAmbient Light SensorAccelerometerMagnetic Sensor |
Location | GPS | GPS |
Speaker | ✔ | ✔ |
Microphone | ✔ | ✔ |
When looking at the table above, you can see plenty of similarities and some stark differences. It may be difficult to fully grasp whether these differences actually stack up, but take it from us — they very much do.
TicWatch Pro 3 vs. TicWatch Pro (2020): Are these watches really that different?
At a glance, it may not be all that apparent how different the watches genuinely are. Both the TicWatch Pro 3 and Pro 2020 share the same lineage in design with the metal and plastic casing, dual pushers on the side, and once powered up, each features a dual-layer display. However, upon closer inspection, and after using the watches, the TicWatch Pro 3 starts to outshine its predecessor.
Mobvoi has managed to enlarge the displays on the Pro 3 while at the same time making the watch thinner and way lighter. These changes don't come at the expense of battery life either. The battery in the TicWatch Pro 3 is 40% larger than the one in the Pro 2020, and it really shows in practice. While running all of the health sensors (these have been upgraded too) with 24-hour tracking and nightly sleep tracking, I got easily three-plus days of usage before topping up on the charger. None of this means that the Pro 2020 has bad battery life by any means. It still gets two days of use but, when it comes to time between charges — more is better.
Be an expert in 5 minutes
Even when turning off the low power LCD, I got nearly three days between charges.
Both of these devices sport a very good film-compensated Super Twisted Nematic (FSTN) LCD panel, which is reflective and transparent. This top layer screen offers high visibility in sunlight and low power consumption. However, the Pro 3 has a much-improved version. The Dual Display 2.0 has received some style changes, a live seconds counter, and a helpful backlight.
As much as the top layer display's reflective nature is a benefit, it's also an Achilles heel because the technology requires ambient external light to be seen. So the addition of the TicWatch Pro 3 backlight allows the low power display to be visible at the lift of a wrist.
If the improved design and battery life weren't enough, daily usability on the Pro 3 is significantly improved with the Snapdragon 4100. The 1GB RAM upgrade on the TicWatch Pro (2020) solved many of its speed problems, but the difference between the Snapdragon 2100 to 4100 is huge. The Pro 3 has the same 1GB RAM but switching between screens, opening apps, scrolling through text, all goes off without a hitch.
Using Google Assistant speeds things up even further. Accessing the digital assistant from your wrist makes sense. Not needing to pull out your phone to set a reminder, ask for directions, or a question should be low friction. However, it was still sluggish and, at times, downright frustrating to use on the TicWatch Pro (2020). The Google Assistant on the TicWatch Pro 3 is finally at a place that using it is as we have always wanted.
The older TicWatch Pro does a lot of the same things that the Pro 3 does, just not as well. In the case of some health-tracking features, it can't do them at all. All of the sensors have been upgraded on the Pro 3, and Mobvoi also added in a barometer and a blood oxygen saturation (SpO2) sensor.
To go with those sensors, Mobvoi has built new apps to use them and refreshed existing apps. There's also a new app called TicHear to help monitor and alert you of overly loud external noises around you.
While on the subject of software Google is rolling out an update to Wear OS this fall that will only improve much of the operating system's daily use features. The TicWatch Pro 3 will be getting that update, but it's unclear if the Pro 2020 will see it or not.
If you have the funds, you should absolutely consider an upgrade. The TicWatch Pro 3 enhances everything from the Pro 2020 and adds new features.
The watch might still be big, but it's much lighter, thinner, way faster, and the battery extends even further than before. While there may have been times when accessing something on your TicWatch Pro 2020 would come with the anticipated delay after a tap, the Pro 3 removes that delay — making quick tasks a reality, on top of using Google Assistant as intended.
TicWatch Pro 2020 is still a good watch. It gets solid battery life, performance is improved over some older devices, and the Dual Display is wonderful. However, in comparison with the Pro 3, it's not a fair fight.
