The Ticwatch E Shadow smartwatch has dropped to less than $76 for Cyber Monday
The Ticwatch E Shadow smartwatch is down to $75.65 on Amazon. This is a smartwatch that regularly sells for around $160. Even when it does go on sale, it only drops to around $128. It has never gone this low before and probably won't again. So get it while you can. It's even less expensive than the renewed version of the Ticwatch S Aurora right now, and the E Shadow version is brand new.
Ticwatch Pro, Premium Smartwatch with Layered Display for Long Battery Life, NFC Payment and GPS Build-in, Wear OS by Google, Compatible with iOS and Android (Silver)
$174.99 $249.99 Save $75
Ticwatch E most comfortable Smartwatch-Shadow,1.4 inch OLED Display, Android Wear 2.0,Compatible with iOS and Android, Google Assistant
$66.98 $159.99 Save $93
$59.99 $159.99 Save $100
$63.75 $159.99 Save $96
The Ticwatch is compatible with both iOS and Android, but it does have features that only work on Android. The smartwatch uses Android Wear 2.0, which you can use to access all your favorite apps. You can customize your watch face or personalize the interchangeable bands to find the perfect look for you while you show off your new watch.
You'll be able to use Google Fit and other fitness apps to track your activities. Count your steps, follow your runs, monitor your heart rate, and more. It has built-in GPS so you can follow your movements. Plus, you can stream music right on your wrist. It is also IP67 rated so it's resistant to both dust and water. You can run in the rain or sweat at the gym without worrying about hurting the watch.
Use the Ticwatch to access Google Assistant. Find the answers you need, get things done with simple voice commands, and set reminders for stuff to do later.
When you first get the watch, charge it for more than two hours. This will prevent sudden drops or a suddenly short battery life in the beginning. Use the watch until the battery is empty then charge it up again the first few times you use it, too.
The E Shadow comes with a 30-day money back guarantee and a one-year warranty.
