Making your appliances smarter takes just $16 and this discounted two-pack of smart plugs
You are now subscribed
Your newsletter sign-up was successful
It's both easy and affordable to make lights and appliances in your home smarter; all you need to get started is a device like the ZOOZEE Mini Smart Plug. They're usually only around $10 each, and today you can even score a two-pack for only $15.99 when you enter promo code WW8HKXKH during checkout at Amazon. That's like grabbing each one for only $8.
These plugs connect to the Wi-Fi in your home so you can begin controlling and scheduling their usage from anywhere using an iOS or Android smartphone or tablet, and whatever is plugged into these smart plugs will be controlled at the same time. They're capable of being voice controlled too; if you have a device featuring the Google Assistant or Amazon Alexa, such as the Echo Dot, you can just ask for the plugs to be powered on or off. You won't need a hub for them either, unlike other smart plug options. Using the app, you can even track your energy usage and see what's consuming the most power in your home. Zoozee includes a 1-year warranty with your purchase.
At Amazon, more than 75 customers left a review for this two-pack resulting in a rating of 4.5 out of 5 stars.
