Don't fly overseas without one of these $8 universal travel adapters
One thing you don't want to forget when flying overseas is a Universal Power Adapter. This essential travel accessory enables you to charge devices in countries with varying AC outlets, and while you could probably pick one up during your trip for a small fortune, you'd save big by staying prepared and buying one beforehand. Consider this Xcentz Universal Travel Power Adapter for instance. It's normally affordably priced at just $13 on Amazon, and by clipping the coupon on its product page and then entering code XCENTZS67 during checkout, you can snag one for only $8.34 right now.
Xcentz Power Strip Surge Protector Cube
$13.99 $19.99 Save $6
With four AC surge-protected outlets and three USB charging ports, you'll be able to provide power to up to seven devices and appliances at once. It even comes with an extra-long extension cord. Use the below code to score its best price.
Xcentz USB-C to USB-A Cable (2-pack)
$5.99 $8.99 Save $3
These USB-C to USB-A cables measure six-feet long each and feature a durable nylon braided jacket to offer better protection than many other competitors. They even come with a lifetime warranty.
Xcentz USB-C to Lightning Cable (6-foot)
$9.99 $13.99 Save $4
This MFi-certified USB-C to Lightning charging cable is built for durability and designed with bulletproof braided nylon. It even comes with a lifetime warranty. This deal is valid on the blue version of the cable with the below promo code.
Xcentz 5000mAh PD + QC 3.0 USB-C Power Bank
$15.99 $21.99 Save $6
Reach faster charging speeds with this portable 18W power bank which features Power Delivery and Quick Charge 3.0. It has both a USB-A and USB-C port for charging two devices simultaneously.
$16.99 $23.99 Save $7
This travel adapter works in over 200 countries and features USA, EU, UK, and AU plugs that you can slide out as necessary when it's time to charge. It's pretty compact when not in use, and lightweight as well, offering little downside to bringing it along on all your travels. The adapter is equipped with two USB ports and a travel plug which allow you to charge up to three devices all at once at 2.4A. It's important to note that this adapter converts the power outlet only; it doesn't convert electrical output current or voltage, and it can't support high power appliances over 1840W like some hair dryers or irons either.
