The Withings Body Smart Scale can help you get fit at one of its best prices yet
The Withings Nokia Body Smart Scale is more capable than most scales when it comes to helping you lose weight, and that's because it does much more than just tell how much you weight. Right now, you can even save on its purchase at Amazon, where it's currently on sale for $48. That's just cents above the lowest price it's ever had there and $12 off its regular cost.
Up to eight users can utilize this scale to track weight, BMI, and more. It also pairs with a free app for iOS and Android to help you set goals, view calorie budgets, and see your history. The scale syncs with hundreds of health apps, including Apple Health, Google Fit, and Fitbit, and there are even special tracking features for pregnancies and infants. You can also use the scale to get weather reports, if that's your jam, which means it could be a big time saver in the mornings.
Remember that weight is only one number when it comes to fitness and health. If you're trying to change your weight, consider adding a tape measure to your order so you can track inches, too.
