Level up your computer's connectivity with VAVA's 8-in-1 USB-C hub at almost half off
Your computer is capable of so much, and with the VAVA 8-in-1 USB-C hub, you can unlock even more of its potential. Clipping the coupon on its product page at Amazon and then entering code 6EFV9QL6 during checkout will drop its price to $31.99, saving you 47% and enabling a new level of connectivity for your computer.
VAVA Ambient Light Rejecting (ALR) Projector Screen Pro
$599.99 $649.99 Save $50
This 100-inch ambient light rejecting projector screen is a perfect companion to VAVA's 4K Ultra Short Throw Laser TV, and with this weekend's summer sale, you can save $50 off its regular price for a limited time!
VAVA 4K Ultra Short Throw Laser TV
$2499.99 $2799.99 Save $300
Vava's ultra-short throw projector can cast a 100-inch screen from just 7 inches away from the wall. That makes it a fantastic option for those who don't have much space otherwise, and it even has a built-in Harman Kardon sound bar.
Vava USB-C hubs and laptop docking stations
Up to 33% off
Do you have a thin laptop with only a single USB-C port for all your peripherals? Get a hub that turns that port into multiple tools you can use for everything from HDMI output to USB-A ports. The docking station does the same thing in a bigger way.
Vava Home Cam Pro security camera
$139.99 $199.99 Save $60
Amazon is offering 30% off the Wireless Cam Pro home security camera system today only. You can save up to $84 on the 1-cam or 2-cam kits while supplies last with prices starting at $140.
Vava 2K dual front and rear facing dash cam
$152.99 $180.00 Save $27
The front-facing camera is capable of 1600p resolution at 30fps. The rear camera has 1080p at 30fps. Uses a Sony sensor and 4 infrared LEDs for excellent night vision. Includes 24-hour parking monitoring and a G-sensor for sudden collisions.
This USB-C hub is packed with ports to connect flash drives, monitors, memory cards, and other devices to your computer. It features two USB 3.0 ports (as well as a single USB 2.0 port), along with an HDMI output that supports 4K video and an RJ 45 Gigabit Ethernet port. There's also a 100W power delivery port that lets you charge your laptop through the hub and two memory card slots, SD 3.0 and TF 3.0, both with data transfer speeds up to 5 Gbps. VAVA even includes a warranty that lasts for more than two years with its purchase.
At Amazon, more than 200 customers left a review for this USB-C hub resulting in a high rating of 4.9 out of 5 stars.
