Cover your bases with the discounted Vantrue N1 Pro Mini Dash Cam at $20 off
It doesn't cost much to back up your story in the event of a vehicle collision. With a dash camera like the Vantrue N1 Pro Mini, you can stay prepared for whatever the road throws at you. Though it's normally priced around $80, today you can enter promo code PSKLEYHX during checkout at Amazon to snag one for only $59.99.
This compact dash cam was designed to make sure it doesn't obstruct your vision while you're on the road. It records 1080p HD video at 30fps and features a 160-degree wide-angle F1.8 six-layer glass lens that offers enough clarity to capture license plates and more. There's a motion-activated parking mode which begins recording automatically if motion is detected directly in front of your car while it's parked, as well as seamless loop recording and a G-sensor that will ensure footage from a collision is locked down and not overwritten. An integrated microphone helps to record audio during each recording as well.
The N1 even features the ability to track your driving route, location, and speed, though for GPS features to work you'll have to pick up this GPS module mount that was designed specifically for this camera. You'll also want to have a microSD card handy to store files on this dash cam; it's compatible with cards up to 256GB.
Vantrue backs up this dash cam with an 18-month warranty. At Amazon, nearly 200 customers left a review for it resulting in a rating of 4.4 out of 5 stars.
