Kasa's Smart Dimmer Switch will bring new life to your lights at home for less than $29
Now at its lowest price yet of $28.79 on Amazon, there's never been a better time to buy TP-Link's Kasa Smart Dimmer Light Switch. Earlier this year, it was priced as high as $50, and it's only dropped this low once before. If you're lucky, you might even see a clippable 30% coupon on its product page at Amazon, though it's not available for everyone.
TP-Link Archer AX3000 Wi-Fi 6 wireless router
$99.00 $130.00 Save $31
Wi-Fi 6 promises speeds up to three times faster than previous generations with four times the bandwidth capacity and 75% lower latency. The router has MU-MIMO tech to cover multiple devices connected at once and Ethernet for wired connections.
TP-Link Kasa KP400 smart outdoor plug 2-pack
$29.99 $50.00 Save $20
Get free shipping with your Prime membership. Each plug has two outlets that can be controlled together or individually. Use your phone or voice control with Google Assistant or Amazon Alexa to control them from anywhere. Weather resistant.
TP-Link Archer A20 AC4000 Tri-Band Wi-Fi router
$139.99 $200.00 Save $60
With a tri-band radio, MU-MIMO technology, Beamforming, link aggregation, and more, this router is perfect for homes with a dozen different devices all trying to connect at once. It supports Windows, Mac, and Linux. Includes a 2-year warranty.
$16.99 $25.00 Save $8
With two outlets you can control two outdoor devices either together or individually. And you can do it from anywhere using your phone or voice control through Google Assistant or Amazon Alexa. Weather resistant with long Wi-Fi range.
TP-Link Archer C7 AC1750 Wi-Fi 5 dual-band router
$49.99 $80.00 Save $30
This great little budget router is capable of data transfer speeds up to 1750 Mbps with 2.4GHz and 5GHz wireless bands. Also has four Ethernet ports for a wired connection. Includes a quick and easy setup wizard.
With this smart dimmer switch, you'll be able to turn the connected light on or off from anywhere in the world using the Kasa app on your smartphone or tablet. The app also lets you schedule times that you want the light to be on or off. Meanwhile, with an Amazon Alexa or Google Assistant device, like the Echo Dot, you can voice control the switch for even faster results. There's also a nice feature that gently fades your lighting on and off with a click of the switch. Best of all, no hub is required to use it. It's likely we'll see other smart devices which can work along with it during Amazon's upcoming Prime Day sale.
More than 250 customers left a review for this smart light switch at Amazon, leaving it with a rating of 4.7 out of 5 stars collectively.
Be an expert in 5 minutes
