Upgrade to Toshiba's 55-inch 4K smart Fire TV while it's discounted to $300
Toshiba Fire TV
Toshiba Fire TV (Image credit: Android Central)
Smart TVs get more affordable every day, but it's not every day that you can score a Toshiba 55-inch LED 4K UHD Smart Fire TV for only $299.99 at Best Buy. Today's that day though, and at $150 off its regular cost via Amazon, you'd be snagging this 4K TV at one of its best prices in history.
Toshiba N300 10TB NAS 3.5-Inch Internal Hard Drive- SATA 6 Gb/s 7200 RPM 256MB (HDWG11AXZSTA)
$277.99 $277.99 Save $0
Toshiba 55LF711U20 55-inch 4K Ultra HD Smart LED TV HDR - Fire TV Edition
$349.99 $450.00 Save $100
All-New Toshiba 50LF621U21 50-inch Smart 4K UHD with Dolby Vision - Fire TV Edition, Released 2020
$299.99 $379.99 Save $80
Toshiba N300 8TB NAS 3.5-Inch Internal Hard Drive- SATA 6 Gb/s 7200 RPM 128MB (HDWN180XZSTA)
$199.98 $207.99 Save $8
$279.99 $277.99 Save $-2
The TV has full 4K resolution with support for HDR as well as Amazon's Fire TV OS built-in. The Fire TV gives you access to all your favorite streaming apps like Netflix and Prime Video, but it also has Alexa-enabled skills and can work with the included voice remote. The remote lets you talk to Alexa, search for titles, switch inputs, control your smart home and more. There are tons of connectivity options with this TV including 3 HDMI ports (including 1 with ARC), a USB port, composite, optical, antenna, audio output, and an Ethernet port. If you have an HDTV antenna like this one you can integrate the over-the-air channels with your streaming channels.
