If you're in the market for a TV upgrade, you might just want to check out this one-day deal at Best Buy offering the 49-inch Toshiba Fire TV Edition with a free Amazon Echo Dot for just $229.99. The TV alone sells for as much as $330 when not on sale and the Echo Dot is currently $30 so you're making a killer saving with this deal.
Toshiba N300 10TB NAS 3.5-Inch Internal Hard Drive- SATA 6 Gb/s 7200 RPM 256MB (HDWG11AXZSTA)
$277.99 $277.99 Save $0
Toshiba 55LF711U20 55-inch 4K Ultra HD Smart LED TV HDR - Fire TV Edition
$349.99 $450.00 Save $100
All-New Toshiba 50LF621U21 50-inch Smart 4K UHD with Dolby Vision - Fire TV Edition, Released 2020
$299.99 $379.99 Save $80
Toshiba N300 8TB NAS 3.5-Inch Internal Hard Drive- SATA 6 Gb/s 7200 RPM 128MB (HDWN180XZSTA)
$199.98 $207.99 Save $8
$279.99 $277.99 Save $-2
The 49-inch set has a 1080p resolution and has 3 HDMI ports plus a USB port for hooking up your existing tech like game consoles and set top boxes, though having Fire TV built-in means the TV itself gives you access to apps from Netflix, Hulu, and more. While its HD resolution might mean it doesn't replace your living room TV, this could be a great budget set for a bedroom or kids play room. It still has all of the Amazon smarts and even supports Alexa skills via the included voice remote. As far as super-affordable TVs go, this one is a smart choice at $100 off.
The Echo Dot gives you easy access to all of Alexa's smarts in another area of your home. You'll be able to control your smart home gear, set timers and convert measurements in the kitchen, and ask Alexa for updates on the weather, news, sports, and more. The smart speaker also streams music from services like Amazon Music Unlimited, Spotify, and even Apple Music. If you're already all-in on Echo hardware, it's totally worth adding Alexa to more rooms in your home with this deal.
Amazon's Fire OS is built into a bunch of TVs from Insignia and Toshiba with various screen sizes and resolutions to choose from. You can score a free Echo Dot with the purchase of any of them right now, so if this particular discounted model isn't for you then it's well worth checking out the range.
Be an expert in 5 minutes
