Keeping track of your phone and keys gets easier with discounted Tile Pro trackers
You are now subscribed
Your newsletter sign-up was successful
Amazon has the latest model of the Tile Pro Bluetooth Tracker on sale today for just $27.99. That's a 20% savings off its regular price. You can save even more if you opt for the 2-pack at $48.99, making each tracker just $24.50.
There are several models of Tile Bluetooth trackers, but they all share one common goal: to help you keep track of your essential items. Using the Tile Pro, you can clip it onto your keys and double press the button on it whenever you need to locate your phone. Within seconds, the Tile App will start making your phone ring, even if it's on silent at the time. On the other hand, if you need to find your keys, you can use the Tile App to cause the tracker to emit a loud ring until it's found.
This upgraded version of the Tile Bluetooth tracker offers twice the range of the standard Tile Mate tracker, going from 150 feet to 300 feet. It also features a replaceable battery; older models of the Tile tracker had to be fully replaced when the battery died, so that's an extremely helpful improvement as well. This model of the Tile tracker has a much louder ring than the Tile Mate or Tile Silm, too.
Using a device like the Amazon Echo Dot or Google Home Mini, you can even ask Alexa or the Google Assistant for help finding your lost items. At Amazon, over 400 customers left a review for the Tile Pro resulting in a rating of 4.1 out of 5 stars.
