The Sony WH-CH700N Bluetooth noise-cancelling headphones are less than $100 right now
The Sony WH-CH700N Bluetooth noise-cancelling headphones are down to $98 at Amazon right now. You can get this deal on both the Blue and Black options. Best Buy has these headphones on sale right now too, including a Silver pair, though they're a few dollars higher at $99.99. They're regularly sold for $198 otherwise.
These headphones are meant to be Sony's entry-level model, and while that means the noise-cancelling isn't as good as something like the $348 Sony WH-1000XM3, the audio quality is still superb. And given this is a 50% discount, the tech is way worth it at this price point.
These headphones last for up to 35 hours and feature Quick Charging to get you back to your favorite music. You'll get 50 hours of noise-cancelling if you're using a wired connection. They have Bluetooth and NFC pairing for fast connections, too. You'll be able to take calls and use your smartphone's voice assistant using the built-in microphone. Using your iPhone or Android device, you can even download the Sony Headphones Connect app and customize the sound.
If you're buying these as a gift, a discounted Spotify gift card would pair perfectly with them. Right now, PayPal is offering 16% off the $30 and $60 Spotify gift cards, bringing them down to $25 and $50 respectively.
