Treat your ears to a Sonos One speaker at a rare $49 discount
Sonos One
Sonos One (Image credit: Android Central)
The first Sonos smart speaker with Alexa built in, the Sonos One is currently on sale at Amazon for just $149.99, which is $49 off and one of its lowest prices in history. This speaker doesn't fluctuate much in price from its $199 regular cost, so when it does you should grab one for another room of your home.
By signing up for a free My Best Buy membership, you can snag this speaker for $149.99 at Best Buy. It's quick and easy to sign up if you haven't already.
The Sonos One adds Amazon's Alexa functionality right into the speaker, so you don't need to purchase anything extra to use voice commands to control it. It can also serve as one part of a multi-room speaker setup, whether you buy multiple Sonos One speakers or add on a Play:1, you can connect them all in one of the best home audio setups around.
The second generation model of the Sonos One was released last month, but Sonos didn't make too much of a stir about it as there aren't too many big changes between the two. Today's deal is for the first model, which is being discounted likely to make room for the next version. All in all, this just makes for a great time to buy.
If you're curious about what all Alexa can do for you, be sure to check out Amazon's Alexa Skills homepage which can unlock a ton of new features and more.
