If you don't yet have a security system that is as smart as the rest of your home tech, Woot has just the deal for you with a discounted SimpliSafe Home Security System. Today only, the 7-piece kit is discounted to $189.99 which is a total steal. While this is the newest SimpliSafe tech, this exact configuration isn't sold as a bundle at Amazon or directly at SimpliSafe. However, if you were to build your own kit with the same items it would cost $289. The default 6-piece The Essentials kit is about the closest pre-made bundle and that retails at $259. It's essentially the same as Woot's offering but you also get an extra motion sensor thrown in with the 7-piece set.
$195.00 $249.99 Save $55
$194.91 $249.99 Save $55
$242.99 $299.99 Save $57
$199.99 $249.99 Save $50
SimpliSafe is a hassle-free alarm system with no contracts and no hidden nonsense. The surveillance system is smart enough it can detect the difference between a pet and an intruder. The alarm monitoring is easy and reliable 24 hours a day. You'll get gentle reminders when you leave windows open and urgent notifications during more important times.
You can integrate up to 100 different devices, so you can always add more sensors later. Also, the base station is compatible with Amazon Alexa and Google Assistant. You'll be able to use your voice control to arm the system, and check on it just in case you forgot. It can also integrate with other systems like August smart locks to keep you secure in other ways.
Your SimpliSafe kit is backed by a 3-year warranty and shipping is free at Woot if you use your Amazon Prime account.
Be an expert in 5 minutes
