We all have so much digital content to store these days from photo libraries to movies, music, documents, and more. If you're looking for an easy way to add more storage to your computer without having to open it up and replace its guts, you should definitely pick up the discounted Seagate Desktop 8TB External Hard Drive. The desktop drive is down to a new all-time low price at just $119.99. When not on sale, it's been going for $140 for the last couple of months and was selling $150 as recently as April.
Seagate Expansion 14TB USB 3.0 external desktop hard drive black
$199.99 $250.00 Save $50
I mean, 14TB is a whole lot of space to work with. Works with Windows PCs and connects easily via USB. It's plug-and-play so you don't need any extra software. Comes with an 18-inch USB cable and 18W power adapter. It is covered by a 1-year warranty.
Seagate Backup Plus Slim 1TB portable hard drive Space Gray
$44.99 $60.00 Save $15
This USB 3.0 drive that's backwards compatible with USB 2.0 and works seamlessly between Windows and Mac without reformatting. Has customized backups and folder mirroring. Comes with a year of Mylio Create and 2 months of Adobe Photography Plan.
Seagate Ultra Touch 500GB USB-C portable solid state drive
$74.99 $85.00 Save $10
Designed to be Android Ready so you can easily manage your phone using the included Android app. Has universal compatibility thanks to the USB-C port so it works on Windows and Mac. Lightweight design with fabric cover. Includes 3-year warranty.
Seagate Expansion 10TB external USB 3.0 hard drive
$169.99 $190.00 Save $20
Uses USB 3.0 for connection and fast data transfer speeds. Backwards compatible with USB 2.0. Plug in the power adapter and USB cable and it's good to go. Just drag and drop right out of the box. Works with Windows. Comes with 1-year warranty.
Seagate One Touch 4TB external hard drive
$89.99 $105.00 Save $15
A simple on-the-go USB drive with a minimalist brushed metal enclosure. Works great as a backup or for portable media storage. Comes with a two-year warranty from Seagate. Compatible with Windows and Mac but may need reformatting for Time Machine.
The main draw of this hard drive is its massive 8TB capacity which gives you tons of space for all your backups and files, but it also has 160 MB/s max speed so moving content around won't take an age. It's plug-and-play for Windows machines and requires a simple reformat to use with a Mac. Your purchase includes an 18-inch USB 3.0 cable and 18W power adapter so you have everything you need to get it set up.
Existing owners rate the drive very highly with an average score of 4.4 out of 5 stars based on over 1,100 reviews.
Be an expert in 5 minutes
