Transfer from an Android device to PC with this $10 SanDisk Ultra 32GB Dual Drive
Transferring files between your phone and your computer can be a pain at times, especially depending on the file size. Thankfully, there are devices like SanDisk's Ultra 32GB Dual Drive which can help you move files in a flash. Today, it's down to its lowest price ever at Amazon of $9.89; it regularly sells for around $13 on average.
No more emails to yourself. No more uploading and downloading the files to Google Drive from one device to the next. This dual drive features a micro USB connector on one side and a USB 3.0 connector on the other end, so you can plug it directly into your Android smartphone, move over your important photos, videos, and more to the drive using the SanDisk Memory Zone app, and then plug it into your computer to quickly back up all of that data. It's capable of transferring files at up to 150Mbps.
If you happen to have a newer smartphone with a USB-C port, you'll want the USB-C version of this drive which is on sale for $13 right now.
Close to 175 customers at Amazon reviewed this dual drive with 4.1 out of 5 stars.
See at Amazon
