SanDisk's 500GB Extreme Pro Portable SSD has never sold for less
Amazon is offering the SanDisk 500GB Extreme Pro Portable SSD for $109.99 today. That's about $40 off what it typically sells for, and it's also a historic low for this item from Amazon. Note that this is for the model with the aluminum enclosure. If you opt for the standard enclosure, you'll pay even less.
500GB is a lot of space. However, videographers and RAW photographers might need even more. Additional capacities are also on sale, either at or close to their best prices.
SanDisk Extreme 1TB portable USB-C NVMe solid state drive
$149.99 $240.00 Save $90
Includes a USB-C 3.2 Gen 2 interface for wide compatibility with USB-C devices like computers and smartphones. Has read/write speeds up to 1050 MB/s and 1000 MB/s thanks to the fast NVMe tech. Also IP55 rated for dust and water resistance.
SanDisk 256GB microSDXC memory card
$50.60 $55.00 Save $4
This is Amazon price matching Best Buy. The 256GB card works with any system that can read it and is officially licensed for the Nintendo Switch and Switch Lite. Has read and write speeds up to 100 MB/s and 90 MB/s. Limited lifetime warranty.
SanDisk Extreme Pro 2TB USB-C portable solid state drive
$309.99 $350.00 Save $40
The SSD has powerful NVMe technology with read/write speeds up to 2,000 MB/s. Of course it works with devices not quite capable of that but you won't get speeds as fast either. It comes with a 5-year warranty from SanDisk.
SanDisk Extreme 1TB external USB-C portable solid state drive
$124.99 $140.00 Save $15
Has a 1TB storage capacity and connects easily via USB-C. Even while on the go, you'll get super fast transfer speeds with read speeds up to 550MB/s. The enclosure itself is rugged and resistant to water, dust, and drops. Works with PC and Mac.
SanDisk 1TB Extreme Portable SSD
$155.58 $163.75 Save $8
This highly-rated SSD features a huge capacity and blazing fast transfers, with speeds up to 1050MB/s. The drive itself is rugged and resistant to water, dust, and drops. All those specs fit perfectly into a compact pocket-sized form factor for easy transport. The SSD is compatible with both PC and Mac. Your purchase includes a five-year warranty.
For more tech deals, check out this one-day sale offering massive discounts on laptops, memory, mics, and more.
Be an expert in 5 minutes
Louryn saves money on everything she buys (which is a lot.) In between waiting for Amazon deliveries, she pines for the next Elder Scrolls installment and checks Reddit for gaming rumors. She also loves Hearthstone, makeup, and beer. Find her on Twitter: @lourynstrampe
