Pick up two Ring Stick-Up HD Security Cameras and save $30
Amazon is offering $30 off when you buy two Ring HD Battery-Powered Stick Up Cameras. No coupon code is required. Simply add two of the cameras to your cart and your total will be $329. Usually, this quantity would cost you $360.
Home security systems are awesome, but they usually require multiple products to achieve their purpose. Get started today and save big.
The Stick Up camera records in 1080p HD video and has both speakers and a built-in mic so you can hear and speak through the camera. Other features include a 150-degree field of view, motion-activated smart notifications, and night vision. It's also compatible with several platforms, including iOS, Android, Windows, and Mac.
You'll get all the tools you need to set up and install the camera quickly and easily. You can use the 30-day free trial of Ring Protect Plus to save, review, and share your videos. Plus, it has Power over Ethernet so you can connect the camera to the internet and power it with the same Ethernet cable.
Louryn Strampe
Louryn saves money on everything she buys (which is a lot.) In between waiting for Amazon deliveries, she pines for the next Elder Scrolls installment and checks Reddit for gaming rumors. She also loves Hearthstone, makeup, and beer. Find her on Twitter: @lourynstrampe
