Make home security a priority with a discounted Ring Alarm system and free Amazon Echo Dot
Ring Alarm (1st gen)
Ring Alarm (1st gen) (Image credit: Android Central)
While you may be investing in technology to make your home smarter, you may not necessarily be paying as much attention to how tech can make your home more secure. However, Amazon is currently offering Ring Alarm home security systems with up to 40% off, with the majority down to all-time low prices, giving you the opportunity to protect your home and its contents for less. The systems come in 5- to 15-piece kits and even bundle in the newest Echo Dot at no additional cost. At this price, it's one of the best Ring product deals you can get right now.
The Amazon-owned home security brand is perhaps most well-known for its line of video doorbells, which also work great with its Alarm security systems. Rather than just protecting your front door, Ring Alarm is a whole home security system with a bunch of smarts. Whichever kit you opt for, Ring Alarm comes with the necessary base station and keypad as well as a variety of motion detectors, door and window contact sensors, range extenders, and even smoke and carbon monoxide detectors, depending on which configuration you pick.
The smallest 5-piece Ring Alarm kit is 32% off and includes a window and door contact sensor, range extender and a motion detector for $169. The $204 8-piece kit gives you two addition contact sensors and one additional motion detector. Kits in 11-piece and 14-piece sizes are down to their lowest prices ever with yet more sensors, and you can save $55 (not to mention the value of the Echo Dot) on the largest 15-piece Ring Alarm system that includes the base station, keypad, seven contact sensors, two motion detectors, as well as a range extender, smoke and carbon monoxide sensor, flood and freeze sensor, and even a panic button.
You'll be able to use these system to get instant alerts for a variety of things including when doors or windows are left open or when the system detects motion in your home. You can monitor it all from your iOS or Android phone or tablet. It's easy to setup, requiring no extra tools or professionals. If you already have other Ring products, they can all communicate with each other and you can continue to add more sensors to your setup over time. You can also use your bundled Echo Dot to easily check or change the status of your alarm. Read more about it in our review.
Adam Oram is a Senior Writer at iMore. He studied Media at Newcastle University and has been writing about technology since 2013. He previously worked as an Apple Genius and as a Deals Editor at Thrifter. His spare time is spent watching football (both kinds), playing Pokémon games, and eating vegan food. Follow him on Twitter at [@adamoram](https://twitter.com/adamoram).
